motor bogs when giving gas
Old Oct 27, 2011 | 02:00 PM
team_lunatics's Avatar
Default motor bogs when giving gas
my motor bogs and then dies when i give it gas. well when i full throttle it. im letting it idle and it just seems to die. when i give it some gas it will bog, so i full throttle it open and it completely dies on me. any one has any idea what the problem might be?
Old Oct 27, 2011 | 02:02 PM
grumblemarc's Avatar
The Grumpiest
Default Re: motor bogs when giving gas
You must want your thread locked.
Old Oct 30, 2011 | 08:07 AM
lilboxx's Avatar
you would probably get more help if you had the make and model of the car and what engine you have other than that no one will beable to accurately help you because we'll have no idea of where to start you could have a k20 and peopled be giving you info and a D15.......... wouldnt get you far
Old Nov 3, 2011 | 06:23 AM
Oh sorry. Its a 95 civic hatch with a f22b1 swap. Rebuilt bottom end with 87mm bore. Je 10:0 compression on pauter rods. Idk if its not getting enough fuel or not?
Old Nov 7, 2011 | 07:56 PM
Any suggestions?
Old Nov 10, 2011 | 04:53 AM
Jonwaldron's Avatar
Check your timing.
Old Nov 10, 2011 | 06:10 AM
The Grumpiest
Is this tuned? At all?
Old Nov 10, 2011 | 08:18 PM
thangnhocngheo's Avatar
Ecu might b on limp mode.. Happen to me b4.. Try switching ecu from some one of ur friend
bigred850
Engine Management and Tuning
Sep 24, 2011 03:31 PM
Neptronix
11
Sep 1, 2008 12:49 PM
99delsol
Nov 28, 2006 08:09 PM
wu tang
12
May 11, 2005 10:38 PM
