em1 shifter has vibration with a grinding noise
Old Oct 27, 2011 | 10:32 AM
HellaFab's Avatar
Default em1 shifter has vibration with a grinding noise
em1 shifter has vibration with a grinding noise when i am at highway speeds (120km/h and over. I am not sure what is causing this and it just recently started.
Ideas?
Matt
Old Oct 27, 2011 | 11:06 AM
low91rex's Avatar
Default Re: em1 shifter has vibration with a grinding noise
Like grinding when you put it in gear or just cruising? If its while cruising ill bet that your exhaust is resting against the shift linkage causing it to vibrate and make noise. My car has done it before I just had to tweak the angle of the piping to get it away from the linkage. Put the car up on four jack stands and crawl up underneath and see if the exhaust is indeed touching it.
Old Oct 28, 2011 | 07:40 AM
HellaFab's Avatar
yeah, i didnt really think of that. my car has a short shifter too which would make the linkage closer to the exhaust... and its 5th gear cruising that i hear it. so in 5th it would be closest to the exhaust.
I just changed my axleback recently too.... i will check tomorrow when i have the car on the stands to crank down the coils.
Cheers,
Matt
pezzy
10
Feb 24, 2010 04:12 PM
Midori Green
Mar 13, 2009 08:33 AM
RSX_S
Jul 8, 2008 08:10 PM
SiKSi2K
Nov 8, 2004 08:31 PM
jdm2k_si
16
May 15, 2004 04:52 PM
