Sputtering into vtec
Old Oct 27, 2011 | 09:46 AM
lopezchris21's Avatar
Default Sputtering into vtec
hey guys. Here is my problem. My car drive fine and all and pulled hard and nice. Its a k24a2 in a 02 rsx. I dropped into third and then threw it into fourth and the car started to sputter and have like no power. The car drives perfect in low rpms and what not. Perfect idle and all. But now at full throttle it goes fine until i hit vtec and bam like no power and sputtering.
any help would be much appreciated. I just placed the plugs like 2 months ago and i wanna put good ones in. Which do you guys suggest?
please help. feel free to text me 954-328-6166
thanks ahead of time.
These were my plugs and they look good.
I replaced them with brand new ngk iridiums and same crap.
car pops vtec but then there is no power and sputters.....
Old Oct 27, 2011 | 10:14 AM
f20cmx5's Avatar
Default Re: Sputtering into vtec
You throwing any codes?
Old Oct 27, 2011 | 11:08 AM
nothing at all
Old Oct 27, 2011 | 02:30 PM
turboteg2nv's Avatar
Check your oil.. vtec won't engage if there's not enough oil pressure. And please don't say "pop vtec".. sounds lame as fVck
Old Oct 27, 2011 | 02:38 PM
ok well vtec engages but doesnt do anything. Which intern means vtec meets its requirements to engage but just perform.
Old Oct 27, 2011 | 04:23 PM
f20cmx5's Avatar
injectors ok? could be turning lean at vtec crossover. Hows your exhaust? Intake? Can it breathe alright?
Old Oct 27, 2011 | 06:48 PM
Car Was driving perfect the way it was for 5 months. Then dropped in third to pass a semi and thTs when it all started. Nothing has changed on my set up. I just dropped gear and pushed the car. Car right now still drives fine until full throttle is applied. Vtec still engages.
Old Oct 27, 2011 | 06:49 PM
I updated a new cal to kpro raising the vtec and to make sure my last cal didnt get messed up but same crap.
Old Oct 28, 2011 | 04:59 AM
gutti9's Avatar
it may be something to do with your vtec solenoid
Old Oct 28, 2011 | 06:59 AM
Are these solenoid like b series where u can just take them of and clean them with carb cleaner?
Old Oct 28, 2011 | 07:38 PM
no one knows?
Old Oct 29, 2011 | 07:53 AM
Yes, you can clean it. You'll want to replace the gasket too.
Old Oct 29, 2011 | 02:22 PM
ay0c0nrad's Avatar
check ur plugs, ur oil, solenoid. those are the only things that would cause ur car to run like that IF*** ur NOT throwing any codes lol
Old Nov 1, 2011 | 04:31 AM
UPDATE. When I first got car compression check was 195-190-190-200 and now after this incident it is 195-190-150-200. I dropped a little oil in cylinder to see weather it was a valve or ring and If it were rings the oil would seal them and the compression would spike but if it was a valve then the oil would escape and compression would stay the same. Well the compression did not move.....
What u guys think? Bent valve? Seal? There is not ticking, knocking, tocking. Anything motor is silent......
Old Nov 2, 2011 | 07:41 AM
Fried piston rings. Now the mad scientist is going to have to rip your motor apart to fix it.
Old Nov 2, 2011 | 02:07 PM
if it was fried piston rings then when i did my wet test the oil would of sealed the rings and the compression would of spikes. Since the compression did not budge that leads to a bent valve.
and when i put my ear closer to the vc i hear a loud tapping.
Old Nov 4, 2011 | 05:50 AM
Do a leakdown test.
Old Nov 10, 2011 | 03:26 AM
I completely rebuilt head and still doing it lol
Old Nov 10, 2011 | 06:27 AM
Just talked to a guy who works at a place that specializes in Acura and hondas and he says it sounds like a burnt lobe lol... Yea? No? Never heard that before...
Old Nov 10, 2011 | 06:52 AM
f20cmx5's Avatar
Like a cam lobe got grinded off? There would be allotr of metal shavings in your oil. Drain your oil into a clean pan and cut your filter open to look for shavings
Old Nov 10, 2011 | 07:14 AM
I just read a post about a s2000 hesitating when vtec engages and people said tune but the guy found out his rocker arms were bad and wasn't giving enough pressure.... How to u check those?...
Old Nov 10, 2011 | 07:22 AM
F20 I didn't. See no scores or anything on lobes and no shavings in oil
Old Nov 10, 2011 | 07:25 AM
So... When I rebuilt head I took my solenoid off and it was clean. Cleaned it out with some carb cleaner and same still doing it.
Old Nov 10, 2011 | 01:22 PM
Ok so a little update. Car pops vtec now and then looses a little power and then around 5500-6000 it starts to sputter. I haven't done anything. Just put head back on an that's all.
Old Nov 11, 2011 | 03:21 AM
This has had to happen to someone else. I have absolutely no clue where to start.....
