Soft Rev. Limiter. How to fix with S300 ?
To complement the built in Rev Limiter, which cuts Fuel/Ignition,
I,m looking for an allternativ way to stop the engine from reving past 9000rpm.
The reason is a close ratio gear set (from mFactory), which limits my top speed to 203km/h in 5th gear.
This fits almost all circuits in Sweden, except Anderstorp, that has a very looooong main straight.
I want to be able to hold 100% throttle for a few seconds, without hitting the Fuel/Ignition rev cut.
Can I loose so much power, by retarding the ignition xx-degrees, between 8800-9000rpm, that the car stops accelerate/reving in 5th gear?
Is it possible to handle the extra EGT, that is caused by the retarded ignition, by adding more fuel ?
I'm running 30 degrees advanced timing in the High Speed table, 70%-100% throttle from 6000-9000rpm.
What is the lowest "safe" timing between 8500-9000rpm?
The engine is a B16A with Blox Tybe-B cams, 12,5:1 comp., ITB, and 4-2-1 5Zigen 2,5'' header.
Power output is 191bhp.
Bets regards.
Bets regards.
hondacummins
Engine Management and Tuning
12
Jul 20, 2014 08:14 PM
