b18b engine shaking after replacing cracked cylinder head
Old Oct 26, 2011 | 11:07 AM
dinthanonh's Avatar
Default b18b engine shaking after replacing cracked cylinder head
need help on why the motor shakes after i replaced the head. It didnt shake when the old cracked head was on. first i just replaced the head gasket for a friend because thats all he asked me to do. the motor ran fine but it had a cracked head. so i purchased a used head from a local forum "carolina-hondas" got it hot tanked and installed it. now the engine shakes like crazy. it doesnt misfire just shakes. checked the timing last night and its good. maybe its the valves. any help is appreciated. thanks
Old Oct 26, 2011 | 02:40 PM
mouab18c1's Avatar
Default Re: b18b engine shaking after replacing cracked cylinder head
Shakes as in? Too much movement?
Old Oct 26, 2011 | 03:31 PM
mark@silbernage's Avatar
A compression test might reveal if you've got one cylinder that is not making the grade (valve seat, adjustment, or perhaps rings...)?
That might cause shaking..
Another cause might be motor mounts, make sure they've all be re-installed and torqued correctly, and that all the rubber appears intact.
Mark
Old Oct 27, 2011 | 05:47 AM
dinthanonh's Avatar
yea way too much movement
Old Oct 27, 2011 | 05:51 AM
dinthanonh's Avatar
Mark
the mounts are fine. the engine ran fine with the old cracked head so i dont think its the rings. im thinking its the valve seat
Old Oct 27, 2011 | 10:09 PM
Wrona's Avatar
was the new head staright before was put on the block ?
Old Oct 28, 2011 | 01:49 PM
Hidenplanvew's Avatar
why would valve seat nmake a motor move to much? You sure your idle is correct?
Old Oct 31, 2011 | 10:37 AM
dinthanonh's Avatar
idle is correct. it shakes worse than just the idle being off
kyky
Honda Civic (2006 - 2015)
Jul 29, 2017 01:36 PM
infinkc
Honda S2000
Jan 16, 2013 08:11 PM
B18B00st
Jul 1, 2005 09:50 PM
91integraLSVTEC
Nov 4, 2004 05:43 PM
Drag-On23
Aug 29, 2003 04:04 PM
