Heater
Old Oct 26, 2011 | 07:41 AM
curtie94's Avatar
Default Heater
Is there vacuum lines in a 1991 Honda Accord heat system. When I hit the gas pedal the fan motor picks up. The heat also is not as hot on high fan speed. The lower the fan speed the hotter the heat. If there are no vacuum lines what else could cause it.
What i've done: Flushed heater core
Changed thermostat with radiator
inspected heat control valve by firewall
The car is a 1991 Honda Accord 2DR Coupe with 170,000 miles.
Its real annoying when trying to heat up the cab on low fan speed.
Old Oct 26, 2011 | 03:46 PM
Lost Again's Avatar
Default Re: Heater
Have you checked the blend door adjustment......
Old Oct 26, 2011 | 05:18 PM
curtie94's Avatar
Default Re: Heater
No How would I do that?
Old Oct 28, 2011 | 03:21 PM
Lost Again's Avatar
Default Re: Heater
Can say that it will help but it costs nothing. Pg 15-31 of the manual shows the process.
Old Oct 31, 2011 | 08:54 AM
curtie94's Avatar
Default Re: Heater
Ok i'll try that and write back.
Kimura97
May 2, 2019 01:01 PM
rriznyk
Oct 18, 2015 08:25 AM
curtie94
Oct 2, 2011 09:46 PM
chechea
Aug 8, 2007 08:56 PM
williamsmh
Sep 4, 2005 10:20 AM
