Crome Free Anti Lag On p72 Code Base??
Old Oct 26, 2011 | 07:33 AM
HondaMotive's Avatar
Default Crome Free Anti Lag On p72 Code Base??
Looking for a script or feature to add in crome free that will build some boost at launch. I see this script for low cam launch control that builds boost but apparently is only for a p30 code base. I have a GSR and built my map with the p72 code so Im kinda stuck here. Been searching google all night to no avail. Any help will be greatly appreciated.
Thanks
HondaMotive
Old Oct 26, 2011 | 08:20 AM
d112crzy's Avatar
Default Re: Crome Free Anti Lag On p72 Code Base??
Retune with p30 code, forget about your iabs.
Or buy better engine management.
Old Oct 27, 2011 | 08:53 AM
I dont use IABs. They just open full at 0/vac and boost. Im having problems understanding the tutral for copying gsr maps into the p30 codebase. I imported the gsr fuel and timing maps but the RPM scale doesnt change. He says in he tutral you cannot edit the first and last colum witch I dont understand because in the pictures it looks like he changes the first colum of the RPM range. When I try to change the RPM range in High Cam i have a hole bunch of extra cells at the bottom. What do I do wiith them?? The last cell I change is at 8900RPM but then the next cell is like 6514 then 7001 or whatever... When I get to those RPMs will it be trying to read the cells below what I added?? Im confused :S I just want to run a p30 Codebase with my GSR maps lol :S
Old Oct 27, 2011 | 09:13 AM
I just tried to edit the high cam RPM range by changing the RPM cells after the 8900 one to low RPM range that it will never hit in Vtec but it wont let me change the last cell like the tutral says. So now I have two 8900 RPM cells. Ugh
Old Oct 27, 2011 | 09:21 AM
Nvm Im noob. I just edited all the last ones to match instead of the top ones. I think I got it now. Thanks.
Ben Huynh
Oct 31, 2013 09:17 AM
RedStarGsr
Feb 16, 2004 02:44 PM
wc
Aug 4, 2003 10:35 PM
shadowdawn
Sep 30, 2002 05:59 PM
