solar flux
Old Oct 26, 2011 | 07:31 AM
hoochhenry's Avatar
Default solar flux
anybody used solar flux instead of back purging when welding up manifolds ?with tig welding or can it be used
Old Oct 26, 2011 | 09:53 AM
titwack's Avatar
Default Re: solar flux
it looks like it can be an alternative, you mix it with alcohol and paste it on the back side of a joint. but for ~50$ for a pound I think that I will stick with back purging
Old Oct 26, 2011 | 10:35 PM
Boosted_B_Series's Avatar
haha, a pound would last for years and years.
I use it, works pretty good.
I bought just a few ounces of it and have been using it for months.
Old Oct 27, 2011 | 04:18 AM
hoochhenry's Avatar
sounds good
Old Oct 27, 2011 | 05:13 AM
tepid1's Avatar
I use it on large diameter tube. IE: downpipe/up-pipe stuff. Works pretty good and there is hardly any sugaring. Helps with penetration too.
Old Oct 27, 2011 | 11:27 AM
9bells's Avatar
OG Fabricator
Could you post pics of the results please? I'd like to see what it looks like. Does it affect the welding at all?
Old Oct 27, 2011 | 01:19 PM
hoochhenry's Avatar
x2 would be nice to see
Old Oct 27, 2011 | 01:43 PM
CVC9216's Avatar
I don't use it much, but I found the best method was to brush the insides, tack the pieces, then wire brush the joint really well before welding. Seemed to me any excess would make it weld/look like crap
Old Oct 27, 2011 | 06:31 PM
SpeedwayCoating's Avatar
Solar flux works well. This stuff goes a very long way so it may seem expensive but its lasts. I used it all the time when I did a lot of stainless exhaust systems.
Old Nov 1, 2011 | 11:53 PM
FredC's Avatar
Solar flux does work well, it's somewhat pricey, and probably not as good as just running an additional hose and back purging with argon
Old Nov 2, 2011 | 03:07 AM
tepid1's Avatar
I can't get pics now, but I will next time I use it....
Old Nov 2, 2011 | 05:09 AM
acidz's Avatar
it works really well for what it is. when i was working at a chassis shop they always used it on any stainless stuff n/a headers, turbo headers, dp, etc and havent had any problems
Old Nov 2, 2011 | 05:14 AM
acidz's Avatar
also i just found this post by david@didrace.com when i was looking around on google for pics 9bells
"Welding stainless steel w/ Solar Flux
I know quite a few people come on here asking about backpurging and I'll mention using Solar Flux every now and then but haven't seen any pictures of it being used so I figured I'd post some up.
Solar Flux is silica based, and when heat is applied to it it turns into glass. When you buy it, it is a powder and you mix it with acetone or brake cleaner and it'll form a paste. I typically buy the empty pint sized paint cans w/ lids at Home Depot and a bristle type brush to mix/apply it. I'd only recommend using Solar Flux on a turbo-back exhaust because there is always a chance of the glass on the backside of the weld falling off and causing damage to something spinning at 10,000 rpms + .
On with the pics - 2.5" 304 Stainless w/ a 309L filler, Lincoln Precision TIG 375 w/ max amps set to 37, 100% argon at 25 flow, gas lense w/ a #7 cup, red 3/32" tungsten "
also check out this link....http://www.motoiq.com/magazine_artic...tion-tips.aspx
Old Nov 2, 2011 | 03:40 PM
hoochhenry's Avatar
Seems good thanks for the picture ,as you were saying might be better just to back purge for turbo manifold
Old Nov 3, 2011 | 12:51 AM
I use it on manifolds, alot of people do.
I don't see how it would damage a turbo, its not like what your thinking. I def wouldn't consider it anything like glass.
Old Nov 3, 2011 | 06:28 AM
SovXietday's Avatar
Anyone have any information on where to buy this?
Old Nov 3, 2011 | 10:52 AM
bo2o's Avatar
weldingsupply dot com burnsstainless also has it
Old Nov 3, 2011 | 07:25 PM
acidz's Avatar
http://www.spdexhaust.com/
Old Nov 4, 2011 | 02:30 AM
tepid1's Avatar
My local Airgas had it on the shelf.
I would advise against using it on manifolds. Can't beat backpurging with those. It does create a thin glass like substance, but it's pretty brittle and shouldn't cause and problems with a turbine wheel.
Old Nov 4, 2011 | 07:25 AM
Dr Pooface's Avatar
Doesen't brake cleaner + welding = death?
Old Nov 4, 2011 | 08:30 AM
I always mixed it with alcohol, which is also very flammable. The point is it evaporates before you weld and leaves behind the solar flux.
Old Nov 4, 2011 | 07:02 PM
TIG WERKS's Avatar
When i welded aircraft exhausts we used solar flux all the time.
bigislandc2
Welding / Fabrication
Dec 15, 2014 07:44 AM
RACEPAK
18
Sep 9, 2010 04:54 AM
{AJ}
Paint and Body
Aug 2, 2009 08:51 PM
Race Egr
Apr 25, 2007 12:00 PM
S9i1R
Sep 29, 2005 07:22 PM
