Loosening Rear Brake Drum Self-Adjuster? 2000 Civic EX
Old Oct 25, 2011 | 08:13 AM
dele22's Avatar
Default Loosening Rear Brake Drum Self-Adjuster? 2000 Civic EX
I was replacing my wheel bearings in the back so I figured I'd swap my drums out while I was at it. Passenger side was a breeze but I couldn't get the drum on the driver's side. Being the idiot I am, I pumped the brakes and the adjuster set itself way too high so the problem is even worse. How can I loosen this thing? Seems like it only goes in one direction, unless I'm wrong.
Really appreciate any advice, this is stressing me out
Edit: Just popped the lever off and threaded the adjuster bolt downward. I assume I can just pop the drum on and pump the brakes to adjust it upward again after everything's assembled
jspinelli8
Jun 4, 2017 08:57 PM
pablopab50
Suspension & Brakes
Jul 8, 2013 04:53 PM
phatmonsters
Jan 27, 2007 12:14 AM
dayaftertomorrow
Apr 2, 2005 06:46 PM
CRITTERMATT
May 6, 2003 10:51 AM
