94 integra ls with b20b swap dies
Old Oct 24, 2011 | 08:03 PM
jdmson43's Avatar
Icon2 94 integra ls with b20b swap dies
Ok i have a 94 integra ls with b20b swap i recently had a problem withmy car when im driving or at a stop and rev the engine stubbers n dies also occurs when im on it n lead off the throttle it does the same ive adjust fitv cleaned.
List of things i did to the swap or has
Ls intake mainifold
Ls ecu
All new injectors
Any ideals will be appreciate
Old Oct 25, 2011 | 04:25 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: 94 integra ls with b20b swap dies
Try the Tech forums
https://honda-tech.com/forums/forumdisplay.php?f=6
Old Oct 25, 2011 | 05:09 AM
LordAphotic's Avatar
where you located if your near me i can check it out for you.
Old Oct 25, 2011 | 10:19 AM
mouab18c1's Avatar
Any cel? Have you tried a chipped ecu with a basemap for the b20?
Old Oct 25, 2011 | 10:40 AM
jdmson43's Avatar
Post Re: 94 integra ls with b20b swap dies
No ecu jus stock i thought about it but i was thinkin its the iacv behind the intake mainfoldbut it started doin it when swap the b20
Old Oct 25, 2011 | 11:14 AM
jdmson43's Avatar
Yes there is exceleration but when you lead off that when it falls down and wants to die but if its warmed up it will die so other words there is no hesitation when you: excelerate
Old Oct 25, 2011 | 01:36 PM
mouab18c1's Avatar
Warm up your car and unplug your IACV. If your idle does not drop or the car does not die then it's a faulty IACV.
Old Oct 27, 2011 | 05:42 PM
jdmson43's Avatar
So I did what you told me to do and it died I'm stuck I ran out of ideas I think it might be the ecu because of the map but I could be wrong,
Old Dec 26, 2011 | 07:46 PM
jdmson43's Avatar
ok still havin the same problem if anybody has any ideas on what it would be feel free to tell me
Old Jan 1, 2012 | 08:12 PM
freaks_smk91's Avatar
I have the same set up 95 integra gs n I recently swapped in the b20z. With my stock ecu.
1st.. did the problem start happening asoon as u did the swap or did it happen a few days,weeks after the swap?.
2. Are u sure all grounds and connections are clean and secure?
3.did u reinstall the spacer on the fuel rail when u replaced the fuel injectors? Is the fuel filter good?not all clogged up n ****
4.is all u timing set correctly??firing order etc?r u off a tooth on ur valve timing??spark plugs gapped correctly?wires cap rotor in good shape?
5.check ur vaccum lines and pcv system...a restricted line is never good.
Also if u rev duz ur car feel sluggish??
Old Jan 1, 2012 | 08:46 PM
once again.. where u located i can find the problem for u for as little as 20 bucks if u are close by... and i guarantee that if u fix whatever it is i find it will fix ur issue.
Nacurtis92
Mar 2, 2017 04:58 PM
jdmboy94
Oct 8, 2009 09:10 PM
trrbl1bmx
Dec 17, 2007 10:31 AM
ubreak_ubuy
Mar 13, 2004 07:52 PM
