97 civic ex dimmer switch/cruise, rpm/speedometer dont work.
Old Oct 9, 2011 | 10:55 PM
mrprofits1's Avatar
Default civic ex cluster lights don't work
hello folks, im having a hard time trying to look at the cluster on my 1997 honda civic ex when driving to see the speed limit when i have to. the gear lights work well "automatic" the warning lights work well too it's just the rpm and the speedomete that don't light up for nothing. today i pulled out the cluster and check the light bulbs "brown color plastic tip" and they look fine not burnt. what could it be?
all help it's appreciated, thanks
Old Oct 10, 2011 | 12:27 AM
virgineg6's Avatar
Default Re: civic ex cluster lights don't work
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Old Oct 10, 2011 | 02:41 PM
mrprofits1's Avatar
any fuses # i could start checking?
Old Oct 10, 2011 | 02:48 PM
mrprofits1's Avatar
the only thing i forgot was the year.
Old Oct 10, 2011 | 03:25 PM
virgineg6's Avatar
Yes but things differ from 95-96
Old Oct 11, 2011 | 05:00 PM
mrprofits1's Avatar
anyone?
it has to be a little thing because the ebgine/oil/brake etc lights work perfect, it just the rpm and speedometer that dont light up. i don't have a manual to check what fuse it could be
Old Oct 11, 2011 | 05:23 PM
honda_civic1993's Avatar
Time to get out the multimeter and start testing! lol I had this happen on my '93 Civic and it was the dash brightness control had gone bad. Checked for continuity and there was none. Swapped it out and it worked fine. Does yours have a dash brightness control? If it's not something simple like a fuse, I'd start there.
Old Oct 11, 2011 | 06:25 PM
virgineg6's Avatar
All those lights and the dash lighting have different sources of power. Does your climate control light up?
Old Oct 11, 2011 | 06:33 PM
mrprofits1's Avatar
i have a 97 civic, i have the dimmer switch don't work at all. i want to check for the fuse but don't know which one to look for.
mrprofits1's Avatar
no the climate control doesn't light up.
Old Oct 14, 2011 | 11:03 PM
mrprofits1's Avatar
i didn't read that right. the climate lights does works, also the dome lights does works. only the rpm and speedometer don't work at all. just to throw it in i have a aftermarket radio don't know if it has something to do?
Old Oct 24, 2011 | 05:25 PM
mrprofits1's Avatar
Default 97 civic ex dimmer switch/cruise, rpm/speedometer dont work.
hello peeps, i have a 1997 honda civic ex i'm having problems with the dimmer switch it doesn't light up the speedometer nor the rpm all the other lights on the cluster work fine, i took out the dimmer switch and clean the dust it had no luck, i also did the jump thing black to red wire and it didn't light up
also the cruise control don't work the light doesn't light up when i try to turn it on, what could it be?
by the way this lights DO work, the turn signals, low/hi beam, fog light, brake lights, dome light, climate lights.
Old Oct 25, 2011 | 05:09 AM
kyden's Avatar
Default Re: 97 civic ex dimmer switch/cruise, rpm/speedometer dont work.
are the bulbs good?
Old Oct 25, 2011 | 10:43 PM
mrprofits1's Avatar
Originally Posted by kyden
are the bulbs good?
i took the cluster and checked the bulbs that have brown plastic and are big they look good. i don't know if i need to check the ones that have wires on them ?
the cruise control switch look like it has a burnt bulb because i could see like brown residue around the bulb , it also had a buld cover in like foil? i couldn't see if that bulb works.
Old Oct 29, 2011 | 03:13 PM
mrprofits1's Avatar
anyone? i really need help on this
Old Oct 29, 2011 | 07:54 PM
Former User's Avatar
Only one thread per topic is allowed. Related threads merged.
Check dash fuses 15 and 25.
Old Oct 30, 2011 | 07:25 PM
fastcars017's Avatar
I think you need to check the fuses. I had the same problem on my 98 civic and I checked the fuses and the fuse that controls my lights on my dash lights was burnt out. So replace that and your good to go.
Old Nov 4, 2011 | 05:29 PM
mrprofits1's Avatar
i checked those and they are fine.
Old Nov 4, 2011 | 05:30 PM
mrprofits1's Avatar
will do.
Old Nov 4, 2011 | 06:02 PM
mrprofits1's Avatar
checked the fuse #30 and it was blowned. i replace it with a spare 7.5a and it fixed my dashlights now i could see the speedometer and rpm
Riceninja209
Jun 18, 2012 07:18 AM
Integra303
Lighting
Dec 9, 2010 01:23 PM
Ran4it2
May 18, 2009 10:14 PM
EGTeK
Mar 26, 2003 10:52 AM
