1994 Acura Integra LS ; Transmission Problem
I need some help, i cant seem to pinpoint the problem on my new Integra. Ill make this as easy to diagnose as possible. Bought the car knowing it needed a transmission, ive just replaced the bad tranny with a JDM GSR automatic transmission (auto-to-auto). The problem arose after finishing the job and testing the car, (in different positions on the auto-shifter)
So in conclusion D4 and Reverse arent working, also the car seems to be lacking a lot of power and acceleration but the engine sounds fine in neutral. Plus, i just replaced stock exhaust with a 2.5in full exhaust system, and ive all JDM solenoids with the USDM ones from the bad tranny including the speedo sensor and both other pieces on the back, i want to know if it can be made to work, i.e. fixable, or do i possibly have a "new" ...bad transmission.
Thanks a lot for any insight you have into the problem!
- 1st gear works fine
- 2nd gear works too
- so does D3, however, D4 works...sometimes, it will work then it seems to slip and just rev after switching into 4th gear. (Has only been tested driving around the block).
- Also i havent been able to get Reverse to work at all since its been back together...
