Timing and sparks plugs ..... help.....
Dose anybody know what I should gap my spark plug and what spark plugs to buy Also how many*degree do I set my timing back to.The motor is a 96 ls and I'm runing 8 psi and the turbo is a evo 10 turbo and what should the*fuel ratios *be at.
So set the timing back to 12-13 degree and gap the spark plug like 22-25 and fuel ratio should be around 12.00 in boost right or am I missing anything.
Haha yes it does. Since you are living in 2003 you might want to upgrade to uberdata, I hear its the new craze and will have tons of support and updates. Also get on moates.net I hear he has this new burner called tha burn1.
( I actually still have my burn1 and it works flawlessly 7 years later)
Well you sync it to 16 degrees. The ecu is constantly changing timing at idle. You lock it in ectune so the ecu stops changing it and you can properly time the engine via the dizzy only.
If you throw a timing light on the engine normally you'll notice the marks on the pulley bouncing around as the ecu is messing with things.
So this what I'm going to doing 8 psi on the evo10 turbo using a Jackson racing fmu till I have the money for a tune. fuel ratio are going to be 12.50 wot and for plugs I'm running NGK 7 gap to 28 and timing set at 13 degrees is that going to work.
