Del Sol carpet
Old Oct 24, 2011 | 02:47 AM
Yukioh's Avatar
Default Del Sol carpet
Any suggestions for a place to get some pre-molded carpet for a '97 Del Sol?
Old Oct 24, 2011 | 03:02 AM
DELshaneSOL's Avatar
Default Re: Del Sol carpet
There around 100 anywhere you look
Old Oct 24, 2011 | 05:07 AM
grumblemarc's Avatar
The Grumpiest
http://www.google.com/search?q=pre-m...ient=firefox-a
Old Oct 24, 2011 | 05:14 AM
http://motors.shop.ebay.com/__?_from...p_id=772216636
Old Oct 25, 2011 | 12:27 AM
Yukioh's Avatar
Cool thanks. I wasn't sure if they would fit properly because I've been told a lot of pre-molded carpets were half-assed but if these are being recommended then I'd definitely pick these up!
Old Oct 26, 2011 | 07:14 AM
morbius18's Avatar
Check out my build thread. I bought the ebay one and have pics. Fit is OK, not perfect. If your carpet is really bad it will be an improvement, just a pain in the *** to install. If you want cheap the get ebay, if you want perfect, try to find an OEM carpet.
Old Oct 26, 2011 | 08:23 AM
Mitchness's Avatar
Morbius is right. Typically the pre-molded ones have pretty bad fitment. Check a yard. The carpet from a yard car will be pretty damn dirty, but if you can get it cleaned right then it will fit the best. Yanking the carpet in and out of a del Sol is a PITA so might as well do it right the first time.
jdspeed99z
16
May 4, 2025 07:23 PM
grape1161
Nov 12, 2010 08:58 AM
z6hatchboy
Paint and Body
Apr 7, 2010 06:16 AM
broketuner-Sol_Si
May 31, 2007 07:10 PM
g3teg97
Dec 9, 2005 04:08 AM
