Tach jumps and engine skips??
Old Oct 6, 2002 | 09:20 AM
blacksheep's Avatar
Default Tach jumps and engine skips??
I don't know what is wrong with my car. My tach will jump around wildly and the engine will skip like it's misfiring whenever the tach jumps. I know it has something to do with the distributor, because if I take the distributor off and take it apart and put it back together and put it back on, it will run fine for a while. Then it will start back doing the same thing. I tightened all the connectors and put dielectric grease on them. I even bought a new rotor button. What could it be?
Old Oct 6, 2002 | 10:27 AM
Audi A4's Avatar
Default Re: Tach jumps and engine skips?? (blacksheep)
maybe its time for a new distributor... change the cap out as well
Old Oct 6, 2002 | 10:30 AM
blacksheep's Avatar
Default Re: Tach jumps and engine skips?? (DRAG lll INTEGRA)
Would the cap cause this? I hate to have to buy a new distributor, cause they are expensive.
Old Oct 6, 2002 | 11:40 AM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Check the coil of igniter in the distributor. I think I recall someone having a similar prob and one of those items was the cause. You may also want to ask this question in the Tech forum.
[Modified by Gee3, 2:41 PM 10/6/2002]
Old Oct 8, 2002 | 11:56 PM
blacksheep's Avatar
Default Re: Tach jumps and engine skips?? (Gee3)
Well I found out that it has nothing to do with my distributor. I put my friends distributor on my car and it still did the same thing. Then I put my distributor on his car and it ran fine. So what could it be? I'm thinking that my wire harness has a short in it. What do you guys think?
Old Oct 9, 2002 | 12:07 AM
piatl7il77's Avatar
have you done anything recent to the car. That may be a cause.Or maybe you timing, wires, swap parts with you friend till you find the problem... happy hunting.
Old Oct 9, 2002 | 06:26 AM
pr0jektdc2's Avatar
Default Re: Tach jumps and engine skips?? (piatl7il77)
time to check your timing!!!!!!
Old Oct 9, 2002 | 06:45 AM
blacksheep's Avatar
Default Re: Tach jumps and engine skips?? (pr0jektdc2)
It's not the timing.. timing is perfect. It's something electrical, cause it's making the tach jump wildly.
Old Oct 9, 2002 | 07:43 AM
thebigshow's Avatar
my car is doing the same thing..plus i'm getting interference through my radio...i hate it, i've changed everything but the distributor..i wasted money on a new cap,rotor.ignitor,plugs, and its still doing it....
Old Oct 9, 2002 | 07:17 PM
thebigshow's Avatar
Default Re: Tach jumps and engine skips?? (thebigshow)
bump...
Old Oct 10, 2002 | 09:35 AM
blacksheep's Avatar
This is pissing me off! I wish I knew what it was. Somebody help us.
Old Oct 10, 2002 | 12:14 PM
junglistgsr's Avatar
Default Re: Tach jumps and engine skips?? (Vert)
is your car grounded properly?
Old Oct 10, 2002 | 09:17 PM
blacksheep's Avatar
Re-crimp all of the connections on your ignitor! I had this same problem too! Also put a dab of dielectric grease inside of the connector b4 you slide it on. Make sure those connections are tight.
I already did that. I even put my distributor on my friend's 95 del Sol with a B18C1 in it, and it ran just fine. So the problem is not in the distributor.
Old Oct 10, 2002 | 09:18 PM
blacksheep's Avatar
Default Re: Tach jumps and engine skips?? (junglistgsr)
I also double checked the ground wire. I don't know what it is, and I'm really getting frustrated.
Old Oct 13, 2002 | 10:08 PM
blacksheep's Avatar
Now my tach has stopped working altogether. I'm puzzled.
s13hero
31
Jun 17, 2016 06:43 AM
Draven8795
Mar 11, 2012 02:49 PM
JasmitH
Apr 28, 2007 06:58 PM
tigueremalo
Jan 28, 2007 11:24 AM
