D16Y7 mystery bracket on block
Old Oct 23, 2011 | 07:36 AM
Nobody123's Avatar
Default D16Y7 mystery bracket on block
This D16Y7 is from a 98 LX. I didn't tear the motor down so I have no idea what this bracket is used for.
It's bolted to the block with one bolt.
I think it's there to hold the fuel return line? But I'm not sure.
Any help would be appreciated.
Old Oct 23, 2011 | 07:56 AM
hyperblu's Avatar
Default Re: D16Y7 mystery bracket on block
support for intake manifold? I would tell you buy i have to leave for work in a second..
Old Oct 23, 2011 | 07:58 AM
Nobody123's Avatar
Thanks for the help, but I checked.
The manifold support bracket goes under the oil box on the right.
Still can't figure out where that bracket goes to.
Old Oct 23, 2011 | 08:08 AM
hyperblu's Avatar
I just checked and the harness coming from the crank along the timing cover clips to the bracket at the connector and there is also a plastic c clip connected to it to hold a portion of the main harness up from dangling. It doesn't serve a purpose really besides supporting clips and harnesses. The notch in that bracket is where the "c" clip slides and locks in to hold the harness.
Old Oct 23, 2011 | 12:40 PM
Nobody123's Avatar
Ok Thank you
Muckman
Nov 27, 2005 06:51 PM
b18_racer805
Sep 29, 2005 07:46 AM
rjay8604
Jun 7, 2005 06:54 PM
vangc6780
Apr 1, 2005 07:41 AM
TuningOptions
Mar 8, 2005 06:37 PM
