1995 Honda Del Sol VTEC Build
Bought this car the summer of 2010. This is how it looked when i got it. Car came from Ontario, and I bought it from a auction as a theft recovery. There was zero rust on the car when i got it just a few small dents here and there.
I put a turbo kit on the stock motor as soon as I got the car. Just a basic setup: OBX log manifold Tial 38mm wastegate, Garrett t3t4 turbo, and 1000cc Precision injectors and welded up a 3" exhaust from Kteller. Ran about 8-10 psi on that.
Over the winter I decided to freshin up the car and change the setup and get some more power. Shaved the antenna and front reflectors and cut out some of the front bumper.
And the result
For the setup I wanted something a little different and a setup that could push around 400whp. I picked up Ectune and a demon for tuning. Stuck with the 1000cc injectors. The turbo manifold is a custom made side winder made by BLAAST paired with a TIAL 44mm MVR wastegate and a custom made turbo also by BLAAST. Went with a 4" thick Spearco intercooler and 2.5" pipings with a HKS SSQ blowoff valve.
Figured it was time to build a engine. Got a blown b16 block for free. Found a B18C on Lowmotion cheep. Bored the block to 81.5mm and put a Supertech block guard in. Went with Supertech coated pistons and Magnitude 4340 Steel H beam rods and ARP rod bolts. A KMS oil pump was added just to be safe. For the head I bought the BC full head kit with stage 2 turbo cams and even got the BC locks. ARP all around to hold everyhthing down including flywheel and pressure plate bolts.
Toped it off with a Edlebrock Victor X intake manifold and give it a whirl.
Had a little bit of bad luch with the car. 1000kms into the new built motor the head gasket blew and a few days after i raced the car at 1600kms my KMS oil pump blew. And of course broke alot of axles and half shafts.
Ran the car at the track. Managed to pull at 12.7 with it. Was hooking up to much at launch and bogging and breaking axles. The car is street tunes to 14psi. I did all the install and tuning myself along with some of the body work. I have alot more parts stocking up now in the basment for next summer. I'm going with a bigger turbo, installing traction bars, new dampener, new BLOX 74mm throttle body, and im going to put a new catch can on it probably a B&R.
Pics and Vids from the track
http://www.youtube.com/watch?v=Ee9Vkow5Kjk
http://www.youtube.com/watch?v=3Z-Rf15EdnY No lsd stock motor in this vid
And the result
Thanks. Still have alot to add and lots to hook up. Im hoping to get in the 11's next summer. Im building a Integra DA as a drag only car and hopefully that will see the track next summer.
rustyshark
36
Aug 21, 2015 04:56 AM
CRXB5
Aug 21, 2014 03:05 PM
WrongWD
Apr 10, 2009 08:54 AM
WrongWD
Apr 10, 2009 08:53 AM
