Replaced lower spark plus seals oil and exhaust now leaking
96 accord 4cyl. I replaced the upper and lower spark plug seals and everything is fine except that there is a slight oil leak near where the exhaust header meets the pipe, there is also a small exhaust leak there.
any suggestions?
any suggestions?
remove clean and reinstall the valve cover gasket this tim using black permatex rtv and then inspect exhaust manifold for crack and if none replace eshaust manifold gasket and retest. (the exhaust gases blowing toward the valve cover gasket may have overheated it and caused the leak)
edited for spelling
edited for spelling
thanks, it not leaking anymore, however it is burning some oil, but it may just be the oil then went into the cylinders after i pulled the spark plugs
keilux
53
Aug 17, 2009 05:43 PM
sony224422
Mar 3, 2008 05:44 AM
Diversion
Aug 12, 2006 11:10 AM
