Taking out the axles
Old Oct 21, 2011 | 02:26 PM
rickriff350's Avatar
Default Taking out the axles
I am trying to get the axles out of my 97 Accord to swap the transmission and am wondering if there is any trick to it or if you just pry and bang on it till it comes loss. Also does it matter which side comes out first? Thanks for any help.
Derrick
Old Oct 21, 2011 | 04:12 PM
reklipz's Avatar
Default Re: Taking out the axles
You should be able to fit a pry bar or a large screw driver between the transmission housing and the housing on the end of the shaft and simply pry it loose. I recently remove the shafts on my 91 Accord, and it was rather simple. There is usually nothing more than a snap ring that holds them in (along with the inability to really move anywhere else once the wheels and such are all mounted, obviously). On my vehicle, as the transmission is further toward the passenger side of the bay, there was an intermediate shaft that the driver side attached to; this snapped out just like it would if it was the passenger side. The intermediate shaft was attached to a bearing (and it's mount to the frame); remove the three bolts, and the shaft/bearing/mount come out as one piece.
Old Oct 21, 2011 | 07:08 PM
Roader's Avatar
X2. Replaced the left axle on my '96 last weekend and it popped right out. There's a 3/8" space between the inner joint and the differential to get a tool in there. A big screwdriver worked great.
Old Oct 21, 2011 | 07:16 PM
Thanks for the replies. I managed to get the drivers side axle out pretty easily by using a pry bar, but the passenger side will not budge. I finally desided that since this one is going to replaced (the boot is torn on it), I am just going to remove the transmission with it in tact. Thanks for all of your help.
Derrick
Old Oct 21, 2011 | 11:44 PM
holmesnmanny's Avatar
You use a prybar to pop it out. If it's being a pest from the bottom move 180 degrees around and try from the top instead. One of the two sides will work.
hu
Mar 24, 2007 03:16 PM
4gen
Aug 11, 2003 04:02 PM
4gen
Aug 9, 2003 08:26 PM
ludicrous
Jul 14, 2001 09:11 PM
