turbo fuel adjustment question
Which adjustment would be the correct way to adjust the fuel. Turbo efficiency or fuel multi .... i have good solid a/f all through but i'm having to run 66psi. the turbo efficiency is at 120% and the multiplier is .68 with blue tops. stock b20 at 8psi the car runs solid and puts down 12.9 in the quarter.
i still need to work on idle but its a track car.
ya fuel pressure.. it is very high i would like to be able to drop it back to the 43 psi but it starts to lean out at about 5500rpms. everything else is perfect. i'm street tuning right now and the cars drives great but wont idle it just wants to idle hop and between 800-500rpms and die. i'm still trying to figure out the correct way to adjust the fuel in the needed areas. I need more fuel across the board to drop the fuel pressure but i only really need more fuel when the boost hits 6.5 psi. Do i change the turbo efficiency or each individual cell?
You need to drop your fuel pressure back down to around 43 psi. Then adjust your fuel multiplier to where you are back in the good a/f ratio area. If you are then having trouble with it leaning out under boost, get some larger injectors. Also wouldn't hurt to hook up a fuel pressure gauge and see if when it is leaning out if the fuel pressure is dropping. If it is, then getter a higher volume fuel pump. You should be running atleast a walbro 255..
i have a friend thats goin to drive tonight will i adjust a few things.
i have it down to 50 psi. i upped the fuel multi to .75 and changed a few cells. I was also able to get the car to idle. just a little more time i should have it.
adjust, adjustment, b20, civic, clearances, efficiency, engine, fuel, honda, pressure, psi, setting, tech, turbo, turbocharger
