Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
>>>>>>BRIAN CROWER & SKUNK 2 CAMSHAFTS ON SALE!!!<<<<< HPSpecialists.com
Old Oct 20, 2011 | 09:49 PM
HPSpecialists's Avatar
Default >>>>>>BRIAN CROWER & SKUNK 2 CAMSHAFTS ON SALE!!!<<<<< HPSpecialists.com
HP Specialists is offering a great sale on Brian Crower & Skunk 2 camshafts at the moment. We offer great shipping quotes as well! Feel free to PM, talk to us on AIM or Email us! We will respond as quickly as possible to make sure that you are as happy with your purchase as we would be if it were for our own cars!
--------PM FOR LOWEST POSSIBLE PRICES-------
Skunk2 Tuner Series camshafts retain factory idle quality and low speed emissions and also significantly increase HP and TQ. When applicable, the VTEC crossover from primary to secondary is more dramatic for that classic VTEC surge. Many of the Skunk2 Tuner Series camshafts also feature Fast Ramp and Amax Technology which allow the engine to build more torque at lower rpms. Tuner Series camshaft profiles are less aggressive than the Pro-Series Camshafts and are designed to place more emphasis on idle quality and emissions. Tuner Series cams use the same high quality cores as the Pro-Series camshafts and are ground on the same CNC cam grinding machines equipped with CBN grinding wheels. Tuner Series camshafts are ideal for both daily street driven and racing engines.
Stage 1: Street/Race cam designed for stock engines with bolt-on modifications. Also good for supercharged applications and aggressive turbo
applications. Upgraded valvetrain recommended, but not required.
Stage 2: Street/Race cam designed for engine with free-flowing intake and exhaust tracts, increased compression, and upgraded valvetrain.
Stage 3: Street/Race cam designed for engines that require the top-end power to carry into higher rpms than what is possible with Stage2 cams.
Turbo 1: Street Turbo cam designed for lower boost, low rpm levels 5-10 psi. Ideal for basic street legal turbo kits.
Turbo 2: Street/Race Turbo cam designed for medium boost levels 10+ psi and slightly higher rpms. Ideal for custom turbo applications and
supercharged applications.
PM FOR LOWEST PRICES!!! PLEASE INCLUDE MAKE AND MODEL!!!
BC high performance camshafts are ground on state-of-the-art CNC cam grinders to insure accuracy and tolerances to within .02mm. Every BC camshaft profile has been prototyped and dyno tested for proven horsepower results prior to placed into mass production. By grinding cores in high volume, Brian Crower, Inc. is able to pass the cost savings on to the end user. Quality at an affordable price.
BC uses small diameter grinding wheels during the finishing phase when applicable to generate a more aggressive ramp rate for a faster cylinder fill rate. More air + more fuel = more power. Although it takes longer to grind the cams, research and development has proven that the inverted radius created by the small grinding wheel on the opening side delivers more horsepower on radius and roller rocker applications than the conventional, large diameter grinding wheels.
All BC cams are checked on a high speed, sub-micron accuracy measuring gauge. The Adcole Camshaft Measuring System uses individual measuring heads for each cam journal and cam lobe, with .01 micron resolution, taking one datum point each 1/10th of a degree or 3,600 data points per revolution. Measuring camshafts for rise error and chattermark detection, this model can measure 200 parts per hour.
I will be online during business hours:
Monday-Friday
10am-6pm
Saturday
11am-2pm
Feel free to ask any questions regarding fitment, performance or pricing through AIM or Email as well as PM. If you would like to address me personally put my name (Chris) in the email as well
AIM: HPSpecialists
Email: HPSpecialists@gmail.com
Check us out online at http://www.HPSpecialists.com
Go "Like" us on Facebook at HP Specialists on Facebook!!
Follow us on Twitter for special sales and updates by following "@HPSpecialists"
Old Oct 21, 2011 | 12:08 AM
Default Re: >>>>>>BRIAN CROWER & SKUNK 2 CAMSHAFTS ON SALE!!!<<<<< HPSpecialists.com
ttt
Old Oct 21, 2011 | 08:32 AM
ttt
Old Oct 21, 2011 | 10:34 AM
All PM's responded!!
Old Oct 21, 2011 | 11:14 AM
More PM's responded!
Old Oct 21, 2011 | 12:44 PM
TGIF
Old Oct 21, 2011 | 03:11 PM
TTT
Old Oct 21, 2011 | 05:33 PM
PMs Responded!
Old Oct 21, 2011 | 08:13 PM
PMs responded!!!
Old Oct 22, 2011 | 10:03 AM
PM's responded! Hope you're having a great Saturday!
Old Oct 22, 2011 | 02:20 PM
TTT
Old Oct 22, 2011 | 10:56 PM
All of the PM's have been responded!
Old Oct 23, 2011 | 12:22 PM
PMs are answered!!
Old Oct 23, 2011 | 03:28 PM
ALL PM'S ARE RESPONDED!
Old Oct 23, 2011 | 06:59 PM
Thanks for all the PM's everyone! Everyone has been responded to! Anything else will be responded to in the morning!
Old Oct 24, 2011 | 09:22 AM
Hope everyone is having a great Monday!!! All PM's are responded!!!
Old Oct 24, 2011 | 10:59 AM
ttt
Old Oct 24, 2011 | 12:44 PM
Busy Monday so far! PM's are responded to!
Old Oct 24, 2011 | 02:18 PM
TOP!
Old Oct 24, 2011 | 03:44 PM
PM'S RESPONDED!! ORDERS ARE PLACED!!
Old Oct 25, 2011 | 10:33 AM
PMS ARE RESPONDED TO!!!
Old Oct 25, 2011 | 11:26 AM
TTT
Old Oct 25, 2011 | 02:27 PM
Old Oct 25, 2011 | 07:09 PM
TTT
Old Oct 26, 2011 | 10:11 AM
All PM's Responded!
