High-HP guys...engine/tranny stiffeners? searched..
Old Oct 20, 2011 | 08:29 PM
xxxmikenicexxx's Avatar
Default High-HP guys...engine/tranny stiffeners? searched..
I have been searching and searching to no avail...what are everyone's thoughts on the tranny-to-engine stiffeners? Anyone with high HP and drag strip passes, etc have any insight?
I have one bolt hole stripped and another not doing so good, and I really just dont want to run them. It appears that with some scattershields that they CANT be run anyways, so Im assuming plenty of high-HP cars run without them?
I havent been able to really find any input, only from one reputable source, but Id like to get everyones input before I make a decision...thanks in advance!
Old Oct 21, 2011 | 04:51 AM
DelSolMarine's Avatar
Default Re: High-HP guys...engine/tranny stiffeners? searched..
tranny to engine stiffeners? take a picture to define what it is your talking about more thoroughly please
Old Oct 21, 2011 | 12:59 PM
MR.johnson's Avatar
you talking about a scatter shield?
Old Oct 21, 2011 | 01:18 PM
h22apwrd95's Avatar
I believe he is talking about the L-shaped aluminum brackets that bolt between the lower section of the bell housing and the bottom side of the block. The B-series engines have 2, and the ITR has that whole sheild assembly.
Old Oct 21, 2011 | 01:36 PM
Yeah, thats what Im talking about. The two OEM brackets.
Old Oct 21, 2011 | 04:43 PM
gc8dc95's Avatar
I dont run one....I only run 12.0, but never had an issue.
Old Oct 21, 2011 | 04:48 PM
m3tech95's Avatar
not sure what your definition of high HP is...but i track 11.9's i run them both... If the OEM designed the motor around it, its likely there for a purpose wether we know what that is or not...but if for some reason you dont run them on your car I wouldnt go nuts over fixing it...
Old Oct 21, 2011 | 06:05 PM
Hidenplanvew's Avatar
The H series have them
Old Oct 21, 2011 | 10:39 PM
I am assume its function is to keep the "unsupported" bottom half of the tranny stable and keep from flex and whatnot. But I want some input from the high-HP guys to confirm that they really are not necessary. I just dont want to go nuts trying to get them on when I am fine without. I do find them rather annoying...lol
eklum
Welding / Fabrication
Jul 19, 2010 08:20 PM
alscrx
Transmission & Drivetrain
12
Oct 20, 2009 03:56 PM
egamjah
Jun 9, 2005 09:25 PM
LSTEG96
Oct 4, 2003 02:12 PM
del_parker
Aug 24, 2002 10:44 PM
