OR FS/FT{{Ls-vtec delsol si}} boosted hard!
NOT for the weak at soul
ls-vtec
8-10k miles on the build
machined 81mm sleeves
nippon racing pistons/rings/pins
balenced ls rods with arp studs/bolts
cometic bottom end gasket kit
apocalypse racing oil pump (ported with billit gears)
acl race rod bearings
acl race main bearings
micro-polished crank
itr crank pulley
Gates racing timing belt
ARP Headstuds
Cometic 81mm/.36 thickness headgasket
hondata intake manifold gasket
B16 head with type r valve cover
custom catch can setup
mild Port N polish
3 angle valve job
STR cam gears (tuned by english)
GSR cams
GSR valves
GSR Valve springs dual intake side
Garage 808 built B16 Tranny with ls 5th gear
ACT 4 puck unsprung clutch with ACT extreme pressure plate
itr flywheel 14lb's
P28 ecu chipped on chrome pro
omni 3-bar map
Garrett 57trim 60a/r with stage 3 turbine
turbonetics bell inlet intake
Ramhorn manifold made by Fam at Forged performance
ETS intercooler
38mm Tial wastegate
blitz bov
660cc injectors
walbro 255 pump
3" downpipe/exhuast made by English Racing
vibrant 3" muffler
dump tube made by English racing
innovative 60a polished motor mounts
full k-sport coilovers
4x114 hub/brake/wheel coversion (96 type r integra)
205 proxi 4's in front
195 falken's on back
skunk 2 lca's
DNA lower strut bars
mugan upper front and trunk bars
full aem wideband air/fuel and tru-boost gauges
apexi turbo timer
skunk 2 short shifter
skunk 2 shift ****
AND A WHOLE LOT MORE!
**only downside is the paint is faded but with just a quick paintjob you can easily throw it in shows or have one of the cleanist and quickest delsol's around the northwest! i won third place import at albany's (daretoocruise) event even with the faded paint!**
tuned by TJ at english
8200 rev limit
5200 2step(launch control)
353whp/254trq 15psi (highboost)
325whp on 13psi (midboost)
300whp on 10psi (wastegate)
HAVE the dyno sheets!
13.06 at 114mph on 10psi (break in tune)
running proxi 205's
With the right wheel set-up this is a easy 11sec car.
ill check back on this thread im intrested in anything flushed/clean/tucked
InTheLBC20
Dec 18, 2010 02:40 AM
