H22A compression test results
Old Oct 20, 2011 | 09:41 AM
sameerb1's Avatar
Default H22A compression test results
Results of compression test of my H22A (which does not start):
Cylinder 1: 90
Cylinder 2: 100
Cylinder 3: 80
Cylinder 4: 50
any suggestions what kind of damage i might be looking at here?
Old Oct 20, 2011 | 11:52 AM
typemismatch's Avatar
Honda owns me
Default Re: H22A compression test results
Have you tried a valve adjustment?
Old Oct 21, 2011 | 12:09 PM
97ludedude's Avatar
Your numbers look low across the board. i would think either head gasket or bent valve. i have never seen a car that would not crank with valves out of adjustment. (not that it is not possible if someone didn't know what they were doing when they adjusted the valves and are all too tight.)
Old Oct 21, 2011 | 01:01 PM
mike541's Avatar
A magic can of Restore should fix that. bahaha. JK!
Brandon Peters
Oct 18, 2015 05:40 PM
shooter93
Jul 17, 2015 04:29 PM
Team_Coast978
Engine Management and Tuning
Jun 10, 2013 10:58 AM
Projectludatic
Oct 8, 2010 06:15 PM
Da1spaz247
Nov 4, 2005 07:57 PM
