92 Prelude speedometer not working and D4 light flashes
Old Oct 19, 2011 | 06:01 PM
Tommin8r103's Avatar
Icon2 92 Prelude speedometer not working and D4 light flashes
Hello all,
I have a 92 Prelude SI that the speedometer doesn't work and after I drive it a block or two the D4 indicator light on the instrument cluster starts flashing. I have replaced the speed sensor and tried 3 different speedometer clusters with no change. I am at my wits end with this thing. Any advise would be greatly appreciated. I also replaced the trans solenoid that is on the top thinking that might fix my D4 light...wrong again!
Thanks!
Old Oct 19, 2011 | 06:10 PM
preludeNApower's Avatar
Default Re: 92 Prelude speedometer not working and D4 light flashes
check your wiring
Old Oct 19, 2011 | 06:24 PM
The wiring from the VSS to the speedometer?
Old Oct 19, 2011 | 06:58 PM
check it for power, check the fuse. It will get power from fuse box under dash. Sends signal to ECU/cluster/cruise control/4ws. It will also have a ground.
Black/yellow or yellow will be power
Black is ground
Blue or orange is the output
Old Oct 30, 2011 | 08:56 AM
They all checked out good! What now?
Old Oct 30, 2011 | 06:33 PM
Wing8806's Avatar
Consider replacing your speed sensor.
Old Oct 30, 2011 | 10:17 PM
CyborgGT's Avatar
^ Read the first post, he did.
I had this problem recently. No speedo, no odo, and the ECU (H22 w/P13 auto + P19 TCU) was in a limp mode to where the rev limiter would cut in at about 6300 and the VTEC wouldn't activate. Turned out I had an open on the ground side of the sensor. Must have screwed something up when I was experimenting with a wire tuck.
But are you sure that little drive link is in there? The tiny shaft with the fins on the bottom (tranny) end? I thought I was absolutely positive I had mine in, turns out it too was missing the whole time after I put the new sensor in. And what code is the D4 flashing? I don't know about Preludes, but in my Accord the connector you need to jump (I installed a convenient switch on my center console. Win!) is behind the kick panel on the right side of the passenger foot well.
Old Nov 1, 2011 | 01:26 PM
The shaft is in the sensor. The D4 light starts a consistant blink when I have driven about a half a mile and will continue to blink a steady rate. I do not have a CEL. I have read elsewhere that I may need a fluid change with Honda Tranny fluid.
Old Nov 2, 2011 | 09:05 PM
CyborgGT's Avatar
Jumping the CEL connector will also give tranny codes with the D4 light.
Old Nov 4, 2011 | 12:07 PM
So jump it and look for the D4 light to flash or the CEL?
Seoul Survivor
Nov 11, 2009 05:42 PM
Import Prelude
Apr 1, 2007 10:56 AM
HmgLauj69
Aug 4, 2005 02:29 PM
aledee
May 17, 2005 08:01 AM
ithinkitsjdm
13
Feb 23, 2005 06:17 AM
