Hard to shift into gears when stopped.
Old Oct 19, 2011 | 01:22 PM
Da_1991's Avatar
Default Hard to shift into gears when stopped.
I have experienced slight "hard" gear shift when stopped, but today it seemed to be really stiff and I would have to put a lot of effort to jam it into gear. This goes for all the gears but is only when I am stopped and in neutral. When I am the clutch pressed down without letting go, it slides smoothly. Not too sure what the problem may be but any thought/help is appreciated.
Old Oct 19, 2011 | 03:50 PM
Hidenplanvew's Avatar
Default Re: Hard to shift into gears when stopped.
master cylinder or slave... pressure bleed...
Old Oct 19, 2011 | 04:05 PM
83rolla's Avatar
yea what tha guy up here ^^^^^ said
Old Oct 19, 2011 | 05:10 PM
fcm's Avatar
fcm
Old Fart
Have to agree, start with a bleed, if you have a hydro clutch, I would also get under the car and check shift linkage, check connection to shifter.
MM&Y of car would help. 94
Old Oct 20, 2011 | 05:10 PM
Da_1991's Avatar
I got a 91 db1. And thanks for the suggestions
Old Oct 20, 2011 | 06:55 PM
fcm's Avatar
fcm
Old Fart
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal make sure 14 & 15 are not bent, [other then where they are supposed to be]
Make sure 15 is not loose, 16 & 19 are in good shape.
Make sure all of 15s mounting hardware is there and tight.
Make sure 15 moves back and forth in 19 when engine is "twisting" from torque.
Make sure shifter is not loose/sloppy in it's mount on the end of 14, [23&25 are tight] and all the parts3, 4, 5, 13 and 24 are in good shape, pay close attention to 5, [bushing] 94
99hondadx
Feb 10, 2017 05:35 AM
F20B_accord
Sep 5, 2010 07:49 AM
ki11a8ee
Apr 6, 2010 11:54 PM
mmajedi
Feb 20, 2008 08:52 PM
scrap1ngsr
Apr 5, 2006 10:41 AM
