Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
>>>Function and Form, F+F, F2, F&F coilovers Type 1, 2 & 2.5<<< Hardparked.com
Old Oct 19, 2011 | 12:00 PM
HardParkedCom's Avatar
Default >>>Function and Form, F+F, F2, F&F coilovers Type 1, 2 & 2.5<<< Hardparked.com
EMAIL ME FOR SPECIAL HONDA-TECH PRICING !
Email:sales@hardPARKED.com
"TheType One Coil-Over (best value) is a full bodied coil-over, with simplicity in mind. We set the dampening characteristics for you, and also chose less aggressive spring rates to match the fixed dampening. But what we did not change was the durability, quality, smooth ride, and lowering characteristics we are known for. Continuing with our belief that quality can be affordable, we priced the Type One suspension to fit the financially conscious tuner's budget. We recommed for the Type One product line for anybody that wants to enjoy performance, quality and great looks in a simplistic way. Install, set your height, and you are ready to roll...!"
constructed with the same materials,philosophy and strength as our Type Two systems.
Features:
Adjustable Ride Height
Dampening pre-set for optimal ride quality during spirited driving.
Adjustable from lower mount, which allows user to retain full shock travel and pre-load adjustments.
Dual Tube shock design for maximum ride comfort and durability.
Steel construction of lower mounts for increased durability and minimal flex under load.
One Year Limited Warranty
Applications:
Acura Integra (90-93 & 94-01)
Acura TSX (03-08)*slight modification*
Honda Civic ( 88-91/ 92-95/ 96-00)
Honda Accord (90-93/ 94-97/ 98-02*/ 03-07*) *V6 model included
Honda Prelude (92-96/97-01)
"TheType Two Coil-Over is our flagship full bodied coil-over. More aggressive than the Type One, we aimed to make it the ultimate street inspired coil-over. Our philosphy was a coil-over designer for street durability, comfort, and style, but can endure the occasional track days. A lot of our customers dream of hitting the track, but the reality is they want to enjoy their pride and joy on the streets as well. A dedicated track car is not an easy task many find out. But thats ok, because we designed a suspension that can let you enjoy the streets or an occasional fling on the track. You pick."
"In achieving this, we wanted to make a stronger product to endure the imperfections of the real world. Steel materials have been used for the lower mounts to give the shocks OEM durability. Spring rates are slightly more aggressive than a Type One, to handle occasional track duties and spirited street driving (we always suggest safe and smart driving on public roads). But this did not sacrafice ride quality. Twin tube shocks are used for durability and a smoother ride on the street. Our goal is to offer you a suspension that can handle the wear and tear of daily driving duties. With the Type Two's 32 levels of dampening adjustment, you can dial in ride and handling characteristics for the street or the track, giving you ultimate versatility."
Features:
One year warranty.
32 levels of dampening adjustments.
Dampening adjustments made with a **** that "clicks" at each level.
Steel construction of lower mounts for maximum strength.
Adjustable camber plates.*
Adjustable pillow ball mounts.*
Adjustable ride height from the bottom mount. [1]
Special oil lubrication to withstand conditions from -40 degrees Celsius to 200 degrees Celsius. [2]
Dual tube shock design for maximum ride comfort.
McPherson strut piston size 50mm.
Double wishbone piston size 43mm.
Applications:
Acura RSX (02-06)
Honda Civic ( 88-91/ 92-95/ 96-00/ 01-05 incl. Civic SI/ 06-Current)
Honda S2000 (99-08)
Honda Prelude (88-91/92-96/97-01)
Honda Fit (09-Current)
"TheType Two.5 takes our popular Type Two adjustable suspension to the next level. Using lightweight EIBACH ERS MOTORSPORTS springs we have improved on an already solid platform. For the customer that wants to enjoy occasional track days, autocross events, or spirited driving the Type Two.5 was developed for you. One of the first benefits of the EIBACH ERS MOTORSPORTS spring on the TYPE TWO.5 is the reduced unsprung mass due to their lightweight construction. In performance applications, saving weight is always an advantage. Another major benefit of the EIBACH ERS MOTORSPORTS spring is their guaranteed spring rate consistancy within 2% . This is a very important factor for the customer that wants to dial in his or her set up precisely to shave down that precious lap time. For the first time in 2 years the Type Two.5 will offer custom spring rate options. You can select from 12kg, 10kg, or 8kg for the front or rear, tailoring the system to your needs."
Applications:
99-09 Honda S2000
88-01 Honda Civic,
90-01 Acura Integra
90-07 Honda Accord
04-08 Acura TSX
92-01 Honda Prelude
Old Oct 19, 2011 | 12:12 PM
Default Re: >>>Function and Form, F+F, F2, F&F coilovers Type 1, 2 & 2.5<<< Hardparked.com
ttt
Old Oct 19, 2011 | 12:52 PM
ttt
Old Oct 19, 2011 | 01:10 PM
bump
Old Oct 19, 2011 | 02:51 PM
ttt
Old Oct 19, 2011 | 03:30 PM
ttt
Old Oct 19, 2011 | 04:58 PM
bump
Old Oct 19, 2011 | 09:42 PM
ttt
Old Oct 20, 2011 | 07:21 AM
ttt
Old Oct 20, 2011 | 07:47 AM
bump
Old Oct 20, 2011 | 08:17 AM
bump
Old Oct 20, 2011 | 09:15 AM
ttt
Old Oct 20, 2011 | 09:31 AM
ttt
Old Oct 20, 2011 | 10:49 AM
bump
Old Oct 20, 2011 | 11:43 AM
ttt
Old Oct 20, 2011 | 12:55 PM
bump
Old Oct 20, 2011 | 01:43 PM
bump
Old Oct 20, 2011 | 02:03 PM
ttt
Old Oct 20, 2011 | 02:14 PM
ttt
Old Oct 20, 2011 | 04:31 PM
bump
Old Oct 20, 2011 | 05:39 PM
bump
Old Oct 20, 2011 | 11:49 PM
bump
Old Oct 21, 2011 | 08:21 AM
ttt
Old Oct 21, 2011 | 09:06 AM
ttt
Old Oct 21, 2011 | 10:52 AM
bump
