cracked sleeve? or how its made?
Old Oct 18, 2011 | 09:22 PM
boostedekhb's Avatar
Default cracked sleeve? or how its made?
i bought a longblock that is sleeved i took the head off to check if it was sleeved and my freind said its cracked but i think its how the sleeve is made not 100% i would like to know b4 i got anyfurther on this build
Old Oct 18, 2011 | 09:25 PM
Default Re: cracked sleeve? or how its made?
hopfully pictures help
Old Oct 18, 2011 | 09:34 PM
Dioxine's Avatar
Is it only between the 2nd and 3rd cylinder?
Old Oct 18, 2011 | 09:39 PM
no it on all of em but has less carbon build up on 1 and 4
Old Oct 18, 2011 | 09:40 PM
Dioxine's Avatar
Looks like it is cracked if you ask me, it goes all the way through the block guard but then again it could have just been made that way. Its a tough call hopefully someone with experience can help you a little more. Hope it was just made that way for you sake, good luck.
Old Oct 18, 2011 | 09:42 PM
LightningTeg's Avatar
Community Builder
These pics. really?
Dioxine's Avatar
Well if you look at pics some freshly sleeved blocks actually look that way. Could just be the build.
Old Oct 18, 2011 | 09:52 PM
sorry best pics i could i can take more tomorrow i know the block guard is part of the sleeving itself and the guard is suppose to be like that im sure but idk bout the line in the cylinder walls
Old Oct 18, 2011 | 09:54 PM
the guard is like that on all 4 so is the lines but you can only really see it on 1 and 4
Old Oct 18, 2011 | 10:58 PM
rich7777's Avatar
Post some better picture's up. We might as well be looking at a blank sceen with those pic's
Old Oct 18, 2011 | 11:14 PM
wolve's Avatar
am i the only one who thinks he is talking about the line between the sleeves thinking they cracked???
to the OP, the sleeves are put in individually! so every sleeve is by itself and is not physicly attached to the next. this makes them seem 'loose' from eachother...
Old Oct 18, 2011 | 11:36 PM
Dioxine's Avatar
I think that might be what he is talking about lol
Old Oct 19, 2011 | 07:03 AM
98integralsB18's Avatar
Yeah, the sleeves aren't cracked at all. look at everyone elses build threads or just go on google you'll see all oem and aftermarket sleeved blocks look like that.
Old Oct 19, 2011 | 07:34 AM
AllShowNoGo727's Avatar
mine has those lines also im pretty sure youre ok!
Old Oct 19, 2011 | 10:42 AM
nonpoint986's Avatar
Those look like darton sleeves, but my block has it too if ya can see it
Old Oct 19, 2011 | 10:43 AM
kbouchard1092's Avatar
Yea im with you....i dont think that is a cracked sleeve lol....its just how the two sleeved line up....they go in indivdually... the crack would around the sleeve inner diameter if it was cracked
the fact that the piston is cleaner than the others may be another issue ( headgasket, or sleeves installed incorrectly and not allowing the headgasket to seal correctly around that sleeve) But the sleeves themselves dont look cracked...the pictures do suck. What you have circled does not look like a cracked sleeve. The block guard are attached to the sleeves not too each other so there should be a line where they meet up
Old Oct 19, 2011 | 10:50 AM
yea the headgasket was bad im just gettting ready to put everything back together and one of my idiot friends pointed it out and it just scared me lol ive never had a sleeved block im taking more pictures right now i was hoping it was how the sleeving was made, and so the sleeves are darton? the guy told me golden egale but idk how to tell
Old Oct 19, 2011 | 10:55 AM
Yes those are darton mids from the looks of it... However depending on who installed the sleeves you could be changing the head gasket again...ensure both the head and block are completly flat with a straight edge and feeler gauge. if not then you should have block resurfaced(especially while you have the block out now). And hope they were installed correctly and you dont have a sunk sleeve. Was it a OEM headgasket?
Old Oct 19, 2011 | 12:37 PM
Darton's Avatar
The sleeves are not cracked. The sleeves are individual pieces so those are the flats between the cylinders.
Old Oct 19, 2011 | 01:06 PM
no it has a 3 layer golden egale 85mm head gasket, and i can see that theyre individually placed but it looks like one is starting to break apart i guess im not sure how to tell. my friend said its just starting to crack but he doesnt work on hondas so im not sure. i took pictures but its really hard to see what he is talking about i might just have to get it looked at cause my camera sucks
Old Oct 19, 2011 | 01:15 PM
turbociv910's Avatar
its normal, but u need to resurface that block.
Old Oct 19, 2011 | 01:21 PM
could you tell me how its normal? i dont see why it would only look like that in #4 and not the others at first i thought my friend was talking about the lines then i can see theyre individually places but the one looks like its starting to seperate i guess im not sure.
and thanks guys for all the help its much appreciated
Old Oct 19, 2011 | 01:53 PM
blackeg's Avatar
it is hard to tell from those pictures, but yeah i believe its normal.
my benson block has the visible line between cylinders and they dont all line up perfectly. i have absolutely no issues and have been super happy with the block in the few years ive owned it
Old Oct 19, 2011 | 04:05 PM
SpeedwayCoating's Avatar
if you really want some help you are going to need some better pictures
Old Oct 20, 2011 | 06:18 AM
93civtegra's Avatar
Ive seen a few sleeved blocks personally and it is normal....
Krueger3
Mar 31, 2011 07:02 AM
NOTDISFA5
15
Oct 25, 2010 04:52 PM
95dc2teg
Oct 7, 2008 01:25 PM
shatchi
Feb 28, 2006 05:43 AM
D0GMAN
Apr 12, 2005 08:01 PM
