What do you all think of these cams?
Old Oct 5, 2002 | 11:00 PM
Ausmith's Avatar
Default What do you all think of these cams?
Toda Spec C's with somewhere between 6000-10,000 miles of use. Everything is great except the #4 VTEC lobes on both cams. Use them or not?
The good lobes...
And now the suspect #4 lobes:
Old Oct 5, 2002 | 11:05 PM
itr1244's Avatar
Default Re: What do you all think of these cams? (Ausmith)
sorry~ no idea
Old Oct 5, 2002 | 11:10 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: What do you all think of these cams? (itr1244)
sorry~ no idea
then why reply?
Old Oct 5, 2002 | 11:39 PM
B2FiNiTY's Avatar
Default Re: What do you all think of these cams? (dLo GSR)
To get an extra post. Why did YOU reply?
Old Oct 6, 2002 | 12:38 AM
itr1244's Avatar
Default Re: What do you all think of these cams? (ExOdy)
haha
then non of you guys know and REPLYed
Old Oct 6, 2002 | 12:42 AM
4-1-1's Avatar
How bad is it on the #4 VTEC lobes on both cams ?
Old Oct 6, 2002 | 01:17 AM
StinkyTofu's Avatar
Default Re: What do you all think of these cams? (4-1-1)
When you rub your finger over it, do you feel anything?
ringgold's Avatar
Depends on how much you getting them for? It doesnt look that bad on the cams in the pic. And its only on one of the lobes per cam?
Old Oct 6, 2002 | 01:39 AM
to bitch at him.
i'll contribute...
if you can feel it with your fingernail, it's really bad.
happy?
Old Oct 6, 2002 | 03:28 AM
Ausmith's Avatar
Default Re: What do you all think of these cams? (StinkyTofu)
Yes, on the frontside and backside of the "ramp" there is a noticeable groove that run horizantally on the lobe. There is also a very thing metal ridge building up on the edge of the lobe - almost like there is metal "squirting" out the side. If I were to run my finger nail across this ridge I could knock it loose.
Ausmith -who is still curious why both the #4 VTEC lobes show these signs of wear with only 6000 miles. Why don't the primary and secondary lobes show similar wear?
Old Oct 6, 2002 | 09:11 AM
owen_the_soyboy's Avatar
Improper Valve Clearances ????
Old Oct 6, 2002 | 10:49 AM
ringgold's Avatar
Default Re: What do you all think of these cams? (owen_the_soyboy)
If you are buying these cams and you can talk the person down to a cheap price I would probably get them. I think that you can send them to Web Cam and they can repair that lobe.
Old Oct 7, 2002 | 06:30 AM
Ausmith's Avatar
TTT for the Monday morning crowd.
Old Oct 7, 2002 | 06:37 AM
Nate B's Avatar
Can you have those #4 lobes resurfaced or will that have a negative effect on the contact area. They don't look too bad from the pics, but if you can catch a finger nail on the grooves I wouldn't feel too confident. Let us know what you decide...good luck
Old Oct 7, 2002 | 07:33 AM
JPP's Avatar
JPP
If there is a ridge build up on the edge of the lobes it means the metal was deformed and you are know out of spec. You are also running the chance of creating uneven wear on the rocker arm if you use those cam shafts. I did not read your whole first post but if you are considering buying those I would think twice.
As for the reasons for such wear...??? Anything that will prevent free motion of the rocker arm is a possible reason. A lack of oil is also to consider.
[Modified by JPP, 11:37 AM 10/7/2002]
Old Oct 7, 2002 | 08:01 AM
Bbasso's Avatar
Default Re: What do you all think of these cams? (JPP)
Do not resurface the cams-
I would advise against, you wonder why???
spinning at nearly 10k RPM-
and to have it break would be horrible!.
get them check by a shop who can do the X-Ray test and see if there are any flaws in the metal and then measure them to see if there is any unwanted ware.
Good luck.
Old Oct 7, 2002 | 08:44 AM
Ex-ITR5874's Avatar
Oh yeah,
if you can feel it, it`s really bad.
Soon, they will lool like my OEM cams.... And will f00k up your head
Old Oct 7, 2002 | 09:21 AM
Ausmith's Avatar
Here are a few more pictures close up on the suspect lobes. If you look closely you can see the metal on the edge of the lobes. I'm just ver curious as to the root cause - more for education than anything else. I was told when I bought the cams that they had "Normal Wear" - needless to say I was disappointed when I opened up the box. I speculate that the valve springs had coil bind or that the #4 rod broke not allowing the valves to open.
Thankfully the person who I bought them from is a quality individual. He was selling them for a friend and didn't take the time to examine the cams. He is going to send me my money back, although I did **** him off from coming on a little too strong once I saw the cams were damaged.
[Modified by Ausmith, 6:23 PM 10/7/2002]
ekim952522000
13
Feb 13, 2006 08:34 AM
neo1z
Apr 15, 2002 06:23 PM
tecnic1
Mar 5, 2002 09:07 PM
duduvr6
Oct 9, 2001 01:30 PM
