Removing 96-00 Dx caliper- Quick How to anyone?
I need to get new brake pads for my 99 Dx soon and my calipers are rusted and look very gaudy.
I would like some tips on removing the whole caliper while I swap out the pads so I could polish them up a bit.
Remove the caliper pins. (14 mm)
Remove the caliper brackets. (17 mm)
Remove the brake hose banjo bolts. Block these off to prevent air infiltration. You will need new crush washers.
Clean you calipers.
Reinstall. You will need to look up the torque specs for the bolts.
Bleed your brakes.
Clean you calipers.
Bleed your brakes.
Nocturnal
Jul 11, 2007 09:29 PM
sleepyhamsterlx
Dec 29, 2003 03:12 PM
