Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Everything you need for the Albins trans to work
Old Oct 18, 2011 | 08:26 AM
wildabeast's Avatar
Default Everything you need for the Albins trans to work
This is a comprehensive list of everything you need to make the albins trans (option 1) to work in the SI 6 speed:
Store | SpeedFactory
Albins Option 1 gear ratios:
*1st-4th gear ratios:
Option 1 - 2.93 / 1.70 / 1.19 / 0.93
Acura part numbers
23580-RAS-010 acura mainshaft 5th
23461-RAS-000 acura countershaft 5th
TSX gear ratio is .825
http://www.acurapartswarehouse.com/o...0-RAS-010.html
http://www.acurapartswarehouse.com/o...1-RAS-000.html
Honda part numbers
23444-PPT-315 3/4 sleeve set
23432-PNS-315 1/2 sleeve set
synchros:
you can use the stock ones... but highly recomended to get the carbon synchros from Synchrotech. If you're spending this much dough to get the trans, an extra $300 will give you smoother shifts and longetivity. Get the 1-6 Synchro set (~$50/synchro)
Synchrotech Carbon Synchros
Synchrotech also offers the 1/2 and 3/4 sleeve sets. If you can get both sleeve sets for under $400, then buy them elsewhere, otherwise get them through Synchrotech as they are super cheap.
If you get the 1/2 and 3/4 sleeves+1-6 carbon synchros from synchrotech, it should cost ~$825
Trans fluid:
Torco trans fluid
RTF racing transmission fluid (get 5 quarts, you'll need to do a trans flush/change after initial break in of 500 miles)
MTF standard transmission fluid
suggested: get a magnetic drain plug. This will help keep metal pieces from floating around and it'll increase longetivity of the trans.
Albins option 2 will be available in August (supposedly)
Gear ratios:
Option 2 - 3.0 / 2.0 / 1.47 / 1.10 (available soon!)
These ratios are better for using the stock 5th and 6th gear.
You'll still need to get the sleeves and synchros for 1-4.
This trans is more for auto-x than drag due to the closer ratios. (assuming stock FD)
the 4.38 is available for $1070 at time of purchase, HOWEVER, it is not needed unless you're going for a pure drag setup with BIG power, or want to use it with option 2
tsx gears 60+70 = 130
sleeves + 1-6 synchros =825
albins trans = 3850
Torco Trans fluid = 20x5 = $100
Magnetic drain plug = $10
Total = 4915 + shipping/handling
OPTIONAL: 4.38FD $1070
Old Oct 18, 2011 | 12:38 PM
HRsi-dan's Avatar
Default Re: Everything you need for the Albins trans to work
Good info. Maybe someday if my tranny dies..
Old Oct 19, 2011 | 07:12 PM
JFK78's Avatar
The store has been updated. Version 2 ratios are now available as well as a whole slew of new available FD ratios have been added!
http://www.speedfactoryracing.net/st...roduct=2521934
THEDirtyDseriesWOOT
Aug 21, 2006 08:48 PM
01-0720
Jun 2, 2005 01:53 PM
RevOnRacerz
Feb 10, 2005 01:12 PM
Ehron
12
Mar 29, 2003 02:53 PM
