questions bout rebuilt
Old Oct 17, 2011 | 09:29 PM
nandito's Avatar
Default questions bout rebuilt
i have a db a rod blew out but i dont know whether to rebuilt it since i dont know what i will need or just get a new bottom block any hints help
Old Oct 17, 2011 | 11:36 PM
doood's Avatar
been there done that
Default Re: questions bout rebuilt
take it to a shop and hand them a blank check. seriously.
Old Oct 18, 2011 | 06:55 PM
fonkernuckle's Avatar
Yeah I would have it rebuilt since when you buy a used motor you could be buying something you already have--a motor that needs rebuild.
Even if you hear it run and runs real good, the sucker can go teats up in a month, happened to me.
You want to save some money then do what i do: Take the head off and take it to a machine shop to get new valve seals and refreshed.
Disassemble the shortblock and take the block to be honed and cleaned, the pistons/connecting rods to have them refreshed and have them install new rings and have them install the pistons into the block. Have the crankshaft refreshed and then take it all home (handle the block sideways so the pistons will not fall out) then place the block upside down (so the pistons won't fall out) on a clean flat surface get a helms manual and begin to assemble the whole engine.You will need bearings etc its all in the manual or you can pay and arm and a leg and get it all done at the machine shop.
Old Oct 19, 2011 | 10:48 AM
nandito's Avatar
ok
can i put a b18b1 into it since i have it sitting there but the engine i have in the integra is a1 so is there a difference in those 2 engines??
im new to new so sorry for the dumb questions
Old Oct 19, 2011 | 11:11 AM
jdmcivic2fast's Avatar
did it blew a hole on the block? most likely when a rod blows out, it makes a hole on the block and most likely everything from the block will be garbage
Old Oct 27, 2011 | 01:40 PM
nandito's Avatar
yeah it blew a hole in the block so im taking the head and everything else out and sell it
Old Oct 27, 2011 | 06:42 PM
DirtyDA9's Avatar
Yea then you can't rebuild it with a hole lol Just use the B18b and have a shop or machine shop (machine shop prefered) measure everything and make sure it's to spec.
Old Oct 27, 2011 | 07:14 PM
sde780's Avatar
You can JB weld it - you can JB weld anything.
Old Oct 27, 2011 | 07:37 PM
DirtyDA9's Avatar
^^^ JB weld and Duct Tape!!! Fixes anything and everything!
Old Oct 27, 2011 | 07:54 PM
Hidenplanvew's Avatar
ya just throw that block in the trash and sell the head
Old Nov 7, 2011 | 05:54 PM
nandito's Avatar
can i just recycle it
Old Nov 7, 2011 | 06:11 PM
Schister66's Avatar
Man U FTW
If it threw a rod, chances are the bottom end is toast. If the rod cracked the block casting, recycle it and move on. Having said that, I would NEVER rebuild a B18A/B unless you were planning to build it for boost/NA/whatever. Those bottom ends, and even long-blocks, are a dime a dozen ... buy another one and swap it.
Not worth it...buy another engine and find someone to swap it for you if you can't do it yourself. You'll be surprised how much work you can get done with a case of beer and a few friends
ge_itr
Jan 20, 2007 12:30 PM
Touch
Oct 18, 2005 10:47 AM
HmgLauj69
33
Mar 2, 2004 07:27 PM
Tropicana18T
Feb 23, 2004 03:40 PM
G_Man604
Dec 2, 2003 10:16 AM
