losing voltage please help
Old Oct 5, 2002 | 10:18 PM
jdmcx's Avatar
Default losing voltage please help
my car seems to be losing volatage when ig et on the car the volts go down to 12 but whenim coasting the cost go back up to 14 what could be wrong bad alternator not tight enough belt bad ground battery help thanks
Old Oct 5, 2002 | 10:23 PM
The_Oz's Avatar
Default Re: losing voltage please help (jdmcx)
How is your idle? I would suspect the belt is loose as well. You also might want to check your voltage regulator (normally found attached to the alternator).
Regards,
Oz
Old Oct 6, 2002 | 07:55 AM
Mikey's Avatar
What? You're losing voltage from where... The battery?
The battery is going to draw more voltage when more and more accessories are on and being used. The car is going to use less voltage no accessories are being used.
Old Oct 6, 2002 | 09:40 AM
jdmcx's Avatar
Default Re: losing voltage please help (The_Oz)
the car idles fine
Old Oct 7, 2002 | 07:04 AM
jdmcx's Avatar
hey my idle is fine i checked the belt and it seems that it has enought tension on it
what happens is it starts up fine and the voltage reads 14v then i drive it and after awhile then it drops to thirteen and then to 12v (car is still driving fine) and the batery light in the dash comes on but the car still drives fine
don't have a clue hope it is not the alternator that thing is a bitch to take out
what is this voltage regulator all i have coming out of the alternator is the green plug harness and the white wire
help
Old Oct 7, 2002 | 07:14 AM
MikeSarr_GSR's Avatar
get a new battery man, then worry about the rest of the car. you can get one at wal-mart with a 3 year warranty for 40 bucks.
Old Oct 7, 2002 | 08:05 AM
jdmcx's Avatar
any more ideas??????
Old Oct 7, 2002 | 10:43 AM
The_Oz's Avatar
Whoa! Do not suspect right away that it is battery. I highly doubt it is. He is saying he's getting 14v voltage on idle, then drops to 12v at high RPMs with the battery light coming on. That is a good sign of the voltage regulator going bad.
jdmcx, just to be on the safe side. Take out the battery and have it load-tested for free. I highly doubt it's the battery, but eliminate the easy ones. If the battery checks out fine, I'm pretty sure it's your alternator. Your voltage regulator is normally attached on the alternator, but I do not know where because I do not own a Civic.
Regards,
Oz
Old Oct 7, 2002 | 12:22 PM
Turbo Powa's Avatar
Its your alternator.
Old Oct 8, 2002 | 09:29 AM
jdmcx's Avatar
it was the alternator i guess it is the voltage regulator (inside alternator) so i have to get a new one
any one have one it is for an obd1 integra
thanks
jason
Old Oct 8, 2002 | 11:09 AM
Turbo Powa's Avatar
Jason why dont you try www.car-parts.com. They have a bunch of shops linked to this site so you can do a nationwide search on anything your looking for.
skipbudlong
12
Jul 24, 2009 03:03 PM
nitrousrush
Nov 2, 2005 03:15 PM
daidilus
22
Dec 27, 2004 09:11 AM
civicqm
Aug 13, 2003 09:16 PM
crxtreme27
11
Aug 28, 2002 11:29 AM
