>>>zomg LCA's CHEAP<<< Hardparked.com
EMAIL ME FOR SPECIAL HONDA-TECH PRICING !
Email:sales@hardPARKED.com
Brands: Blox, Buddy Club, D2, Ksport, skunk2, DME
Blox
$110/$115
BLOX Racing rear lower control arms (LCA) are manufactured from forged AL6061, and are designed as direct replacements for the weaker, factory components.
These extremely strong LCA's help reduce the overall weight of the vehicle’s rear suspension and increase its responsive. These light weight units keep the geometry of the factory suspension intact.
Buddy Club
BuddyClub P-1 racing Lower Control Arm are made with 6061 Aluminum complemented by superior durability and anti-corrosion material design. Manufactured using a precise CNC machine process with high quality material (TPU Phermoplastic polyurethan) that allow for long lasting LCAs resistant of the extreme wear and tear induced by the racing environment.
available in black and bronze
D2
D2 Racing lower control arms reduce unsprung weight by over 30% over your stock units. Constructed of aircraft quality 6061 aluminum and powder coated with the distinctive D2 ceramic coated purple. D2 Racing lower control arms also solve rubbing problems that can result in lowered cars with wider tires.
Ksport
Ksport extreme lower control arms are for Honda Civics and Acura Integras. These reduce unsprung weight by over 30% from factory LCAs. Made from aircraft quality 6061 aluminum, they are built to withstand maximum abuse. They also answer rubbing problems when lowering the vehicle with wider tires.
Skunk2
Skunk2’s Rear Lower Control Arms are based off of the same technology the company’s been using on its own race cars for more than a decade and are a must-have for enthusiasts looking to fine-tune their suspension for maximum handling performance. Skunk2’s Rear Lower Control Arms are direct replacements, maintain OEM suspension geometry, and are ideal for street and race applications. Each arm is forged from aircraft-quality 2024 billet aluminum, precision CNC-machined, and is more than 25 percent lighter than the OEM arms. Skunk2 Rear Lower Control Arms also feature adjustable anti-sway bar mounting holes for advanced suspension tuning and optimum balance.
available in gold, polished aluminum, hard anodized and black
DME
DME Adjustable Suspension Arms can be dialed in for the proper amounts of toe, caster, and camber depending on vehicle usage. Depending on application our arms are equipped with pillow-ball bushings or hardened rubber for direct suspension feedback. DME suspension arms offer ample amounts of adjustability and a superior strength design. Our suspension components provide the perfect solution from a mild to aggressive setup. DME products are a must for all street, track, and drifting vehicles. Professional alignment is highly recommended.
Blox
$110/$115
Buddy Club
D2
Ksport
Skunk2
DME
