95 Civic NO Spark
Old Oct 17, 2011 | 02:17 PM
jun10r27's Avatar
Default 95 Civic NO Spark
Okay so i was driving my civic. and all of a sudden it lost horsepower. and sounded like it was running on 3cyl. i drove about 1 mile to my uncles and the spark was weak. then all of a sudden it just died.
i checked the fuses. fine. timing belt. fine. checked the igniton coils ohms. and they were good. .8 and 14.5. checked voltage on module and had power. also turned key to the on pos. and got 12v to the spring thing off the coil... cap.rotor.plugs. and wires all new.. getting no spark to the cap at all. even tried a new cap.. idk what else to check. even though the ohms on the coil were fine. it could still be bad right?
Old Oct 17, 2011 | 02:55 PM
gotz2b16's Avatar
Default Re: 95 Civic NO Spark
Possibly your ignition module. You can get them for like $40 at Oreiley auto parts.
If/When you install it, make sure you use Heat conductive compound like the stuff you use on the heatsink of your computer at home.. Put it on the metal back of the module between the module bracket in the dizzy, and put it on the surface of the module bracket that touches the dizzy housing when installed.. If not, the module can not dissipate heat and will overheat and fry like the one you have right now just did..
Old Oct 17, 2011 | 03:14 PM
jun10r27's Avatar
all of a sudden it just decided to fry? well i put another one in from my friends dizzy and it did nothing so i think i can rule that out?
Old Oct 17, 2011 | 03:30 PM
Former User's Avatar
Did you subtract the internal resistance of the multimeter from the primary winding resistance of the coil?
Old Oct 17, 2011 | 05:56 PM
jun10r27's Avatar
there was no internal resistance. it was 0.00 when i tested. both the coil's primary contact point and then between the coil positive teminal and to the secondary winding terminal where within specs.
Old Oct 17, 2011 | 06:07 PM
Did you test for internal resistance by touching the two meter probes together? What Ohm scale did you use to measure the primary winding resistance?
Old Oct 21, 2011 | 07:03 PM
jun10r27's Avatar
well i changed the cap and rotor. no go. changed the ignition coil. still nothing. i smell fuel so its spraying into the block i assume. checked fuses. rotor is spinning so timing belt cant be busted. the module is fine. i tried 2 of them. did nothing. should i just buy a dizzy off ebay?
e-roc88
Nov 1, 2010 03:39 PM
ludemach23
10
Oct 11, 2009 01:11 PM
JDMtegg19
Sep 25, 2009 07:37 AM
ex_ricer
Aug 14, 2008 02:14 PM
ob1coby
10
Jun 25, 2007 11:03 PM
