Laguna Seca Blue Civic Built K20 Turbo, 5lug, recaro, work wheels
SOLD!!! Moderator Please Delete
FS: 2001 Civic Coupe. EX model. Laguna Seca blue paint. registered. Clean title. Really clean car. I hardly use it because I have another car. I start it up every week and take it out on weekends Oil always changed at 2.5K miles. Well maintained. clean car. built with the reliablilty of daily driving. Odometer reads only 97k miles. Engine was built last year (only has 9k miles since build) I have reciepts and dyno sheet.
This car is a beast tuned at 403whp 278tq at church automotive very fast.
****with bigger injectors and a retune it will make more power.* this engine was built to handle high boost. It's has only seen 14psi. plenty of room for more power.****
body
Honda HPF rear lip and acura el sideskirts, custom fitted eg BYS style front lip
(I also have a spoon style if interested).
jdm stanley clear honda headlights. Tsunami rear roof wing
engine
Hasport mounts
fully built k20A2 block sleeved with la sleeves
built by Erick's racing
86mm 9:1 comp Arias pistons
crower rods
s2k oil pump
erl s2k oil pump kit
k24 oil pan
new honda bearings
cometic head gasket
arp head bolts.
stock crank
k20a2 head
supertech valve springs and titanium retainers
stock cams
RC 650CC injectiors
walbro 255lpm fuel pump with fuel return line.
hondata IM gasket
BDL 70mm TB
BDL fuel rail
BDL inline fuel filter
turbo
k20 log style cast iron manifold
garret gt3076r oil/water cooled ball bearing turbo.
tail 44mm wasgate
tail 50mm bov
2.5" polished intercoler piping
huge front mount intercoler 26x11.5x3
Koyo aluminum radiator with dual fans
Hondata 4bar map sensor
Hondata boost controller solenoid
custom v band 3" downpipe
custom 3" mandrel bent full exhuast catback with a 3" vibrant muffler (pretty quiet)
ECU
Hondata Kpro
Transmission
type s 6 speed transmission
act lightened flywheel
act sprung clutch (for daily driving)
quaife LSD
rsx s axles
replaced all tranny bearings
revo technica short shifter
Brakes and suspension
rsx type s 5 lug brakes with drilled and slotted 11.5" rotors
Goodridge stainless steel brake lines
Tein Super Street coilovers (also have function and form type 2's available.)
skunk 2 rear camber kit
arp front wheel studs
neochrome extended lugnuts
no name front and rear strut bar
progress 24mm rear sway bar and brace
megan racing blue anodized lca's
wheels
WORK Miester S1 2 piece wheels
16x7 +35 front tires new falken azenis rears are falken 912's
Interior
clean red DC5 type r front seats
wrapped rear seat in black vynil
apexi turbo timer
autometer guages boost oil pressure and water temp (water temp isn't wired in)
PLX digital display widband a/f ratio.
black interior clean.
audio
kenwood 7015x touchscreen dvd player
audiobahn amp
2 12" kicker L5 solobaric subs
alpine type s rear speakers
battery mounted in the trunk.
selling for $11,000 obo will sell for less without seats or without seats and wheels
[B]new price $10,000 as it stands
*or$8500 without work miester wheels and dc5 recaros.
serious inquiries only.email me at the above link for pictures and more info. over 20k invested.
I prefer cash, but I will trade for a s2000.
body
engine
Hasport mounts
crower rods
s2k oil pump
k24 oil pan
new honda bearings
cometic head gasket
arp head bolts.
stock crank
k20a2 head
stock cams
RC 650CC injectiors
hondata IM gasket
BDL 70mm TB
BDL fuel rail
turbo
tail 44mm wasgate
tail 50mm bov
ECU
Hondata Kpro
Transmission
quaife LSD
rsx s axles
wheels
Interior
apexi turbo timer
audio
audiobahn amp
