High idle after fuel filter/cap/rotor install...?
So I put a new fuel filter, rotor and cap in my Integra yesterday. I've driven it maybe 30 miles since and I've noticed that sometimes when I come to a stop the idle first drops to ~750 RPM (where it use to be) then quickly bumps to 1.5K RPM. I pulled the negative battery terminal when I did the work so maybe my ECU is just re-learning things? What do you guys think? I don't think i created in vacuum leaks while doing this work but I haven't really checked yet.
bump! It seemed to be a little better on the way home from work yesterday and to work this moring. Hopefully its just the ecu learning?
bump!?!? Anyone? If I have time this weekend I think I'm going to try to clean the IACV out.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
hondachris1994
11
Mar 24, 2008 01:02 PM
maxxdout
Jun 21, 2002 06:04 AM
