Engine stutter/misfire
Old Oct 17, 2011 | 10:24 AM
hispanic panic's Avatar
Default Engine stutter/misfire
I'll be checking to see if its throwing a code later today, but i've been noticing a slight misfiring (seemingly) in the 1.5-2.5k range when accelerating normally.
Periodically, the engine will loose power and i'll start slowing down unless i floor the pedal, then the power will pick back up and it will start firing normally. Then i goback down to part throttle and it starts stuttering again. Power will completely cut off usually with some stuttering untill i floor it. After about a min or two of going back and forth, it'll return to normal.
I've already replaced plugs, wires, dist cap & rotor, & ignition coil. I noticed my engine is noticibly more responsive, but i'm still stuttering. I ran seafoam through my tank a month ago. Increased my mpg by like 4-6. The only thing i can think of is maybe my fuel pressure regulator is stuttering?? Maybe fuel injectors are going bad??? I dunno WTF....
I'm not having any problems idling or starting. No excessive cranking, no backfiring, absolutely nothing i could notice. Aside from my a/c leaking out overnight.....
btw i have a 98 EX, 4cyl 5 speed.
Old Oct 18, 2011 | 04:03 PM
poorman212's Avatar
Default Re: Engine stutter/misfire
If there are NO ocdes.
I think the 6th still had the same egr ports as the 5th 4cyl's......just offering something to think about...almost the right rpm range,,,,,only when warm (closed loop), light accel....
Next might be a lazy O2-
Old Oct 19, 2011 | 12:38 AM
holmesnmanny's Avatar
First thing I can think of is have the TPS checked. It could have a bad spot on it.
Old Oct 19, 2011 | 06:31 AM
cpberry1's Avatar
Seafoam through the intake will clean it up and likely cure your acceleration problem - it did mine, on the same car, though mine only did it for a mile or two until warmed up. I took my intake completely apart and cleaned it up only to have it happen again two weeks later. Seafoamed through the brake booster, though I didn't let it sit in there for 10 minutes like they suggest. I just put 1/3 can in, let it bog down last little bit, and drove a few spirited, but safe, miles. No problems now for 2 months.
Hope this helps.
PB
Old Oct 19, 2011 | 10:47 PM
http://www.youtube.com/watch?v=0lBPD...eature=related
He tests a bike but it's really the same thing on a honda TPS.
http://www.clubintegra.com/board/showthread.php?t=21792
That's how to calibrate it if you buy a new one. You can get 'em from rockauto dorman makes em.
RebelriderMike
Classic Hondas
Nov 3, 2017 04:45 PM
aquamander
Jun 17, 2015 08:09 PM
paranemertes
May 11, 2015 09:46 PM
el_espiritu
Oct 17, 2012 07:06 AM
madcat501
Honda Civic (2006 - 2015)
Jun 29, 2010 05:43 PM
