radiator fluid level question...need help real quick
ok, i just put my radiator back on after installing my turbo, but i'm not sure how much radiator fluid to add...
do i fill until the radiator is full? because right now there is no fluid in the reserve tank at all, but the radiator is full (even when hot, no fluid)
add it to the resevoir?
Yes if the radiator is bled and filled properly you have to add fluid to the COLD mark on the resevoir. Then once you get it upto operating temp it should be at the HOT mark... HTH
97civic123
Oct 11, 2008 08:08 PM
