Classic Hondas All Pre-1988 Hondas.
1986 honda civic si fuel problem
Old Oct 16, 2011 | 11:55 PM
ke7joi's Avatar
Default 1986 honda civic si fuel problem
Is there some trick to priming the fuel system after the tank is drained and repaired car just cranks.
Old Oct 17, 2011 | 07:13 AM
Gustav129's Avatar
Default Re: 1986 honda civic si fuel problem
It would have an inline fuel pump. Turn the key on to the Run position, and let it sit for a few seconds. Then cycle the key a few more times between off and run.
There's a schrader valve on the fuel rail. After you cycle it a few times, take a screwdriver and press on the schrader valve to make sure you have fuel there.
Old Oct 17, 2011 | 07:28 PM
rrambo4u's Avatar
it lives...we just didn't have enough fuel in the tank.......we even took it around the block to. not bad for not running in 6 years either.
Old Oct 18, 2011 | 12:34 PM
Gustav129's Avatar
Change your fuel filter ASAP. Right there on the firewall.
Old Oct 18, 2011 | 09:13 PM
rrambo4u's Avatar
yeah we are already planning that, have to wait until the next paycheck
it isn't our daily driver, it's our gas saver
Old Oct 19, 2011 | 07:03 AM
Gustav129's Avatar
They are only like $10-$20. Who knows how clogged it is now. It'll burn up your fuel pump.
Old Oct 19, 2011 | 09:07 AM
rrambo4u's Avatar
like i said it will have to wait, we don't live in the city, we are 60+ miles from the nearest autoparts store. it isn't being run anyways....it needs licensed and insuarance and all that good stuff
Old Oct 21, 2011 | 03:08 PM
ke7joi's Avatar
next problem is to solve all the frontend bushing and strut noise`s
Old Oct 22, 2011 | 09:24 AM
Gustav129's Avatar
Originally Posted by Gustav129
Why do you say it's dead? Did he wreck it?
New Bushings:
http://www.energysuspensionparts.com...rod=16%2E18101
New Torque Arms from these guys, up to 29mm and they run about $280 last I checked:
http://www.opmautosports.com/index.html
Tokico Struts, or if you are lucky, a used Tien Coil Over kit....
Ajsbored
Jul 15, 2013 11:40 AM
crnimacak
Apr 21, 2006 10:11 PM
Understeer
May 7, 2004 11:15 AM
eg6_lsi
Mar 25, 2004 10:29 PM
dustin
Feb 8, 2002 06:41 PM
