Need your Emanage suggestions
Old Oct 16, 2011 | 06:39 PM
406EVO's Avatar
U MIRIN?
Default Need your Emanage suggestions
Hey guys,
I have a 97 Integra LS, stock b18b1, with the full greddy 18G turbo kit. It is currently running GReddy Emanage basic. I could tell the car was just not running to her full potential, so I installed an AEM wideband to see how rich/lean she was. Idling and below boost the ratios were normal, but once put under boost, it goes SCARY lean (16s-17s). I am running RC 330cc injectors, everything else on the fuel side of things is stock. Is this just a matter of a bad tune? The emanage preset tune has not been altered, which I have thought was meant to run rich anyways? Are there other potential possibilities in such a lean ratio under boost?
Thanks and I appreciate your guys' opinions,
Corey
Old Oct 17, 2011 | 03:01 PM
crashsvg's Avatar
Default Re: Need your Emanage suggestions
the car needs tuning... how much boost are u running?it runs fine b4 boost because it running off the o2sensor when the car begins to boost u need to tune the car in boost. and 330cc is a lil small for boosted application try 440cc and take the car to a tuner.
Old Oct 18, 2011 | 10:39 AM
406EVO's Avatar
U MIRIN?
It is running 6 lbs.
Judge Owens
Feb 28, 2015 06:00 PM
jdm91CrxSi
Jun 28, 2008 08:25 AM
SiBirdie
Nov 8, 2003 05:15 PM
Andrew 825SM
Sep 22, 2002 01:26 AM
