Loose, rusty scale from cast iron manifold
Old Oct 16, 2011 | 11:50 AM
Mikey3000's Avatar
Default Loose, rusty scale from cast iron manifold
There's a bunch of this stuff on the flanges of my turbo manifold and I would like to know the best way to remove as much of it as I can. I took a welding wire brush to it but I can't get in the runners. What do you guys suggest? I'm thinking this stuff is a danger to a turbo, isn't it?
Note: the entire manifold isn't cast iron, just the head and turbo flanges.
Old Oct 16, 2011 | 04:36 PM
k24em2's Avatar
Default Re: Loose, rusty scale from cast iron manifold
Sandblaster
Old Oct 17, 2011 | 06:09 AM
joein's Avatar
Another way to do it is hold your manifold with the flange down, and tap the sides of the flange all around with a hammer (really loose stuff will fall right out), then rake a screwdriver around the edges to get anything else off that's really loose. They make small wire brushes like toothbrushes, which you'll find at your welding supplier - you can use that to finish clean. If it doesn't come off with the hammer and screwdriver, it isn't going to come off with normal engine vibration.
I believe they also make barrel-type wire brushes that will go on the end of your die grinder also, but a wire brush won't take off any but the loosest scale - it will just polish over it. So I would not use a wire brush for your main cleaning method in this type of situation.
Whatever you do, blow it out really well with air afterward or you'll have created more of a problem than you've solved, especially if you use a sandblaster on the inside of your manifold.
Old Oct 17, 2011 | 07:48 AM
Mikey3000's Avatar
Sweet, thanks guys.
Old Oct 19, 2011 | 05:11 PM
xzodiackillerx's Avatar
http://www.evaporust.com/
it works great after you degrease and get the big chunks off
Old Oct 19, 2011 | 05:37 PM
SpeedwayCoating's Avatar
A solution of muratic acid and water will get the rust off . Just let it soak for a few hours. But it will almost instantly flash rust if u do not apply something to protect it.
Columb0
Welding / Fabrication
10
Sep 26, 2005 06:35 PM
ThePro
May 20, 2005 08:50 AM
jon volk
Apr 12, 2005 12:18 PM
SeanEF
May 26, 2004 09:42 AM
UltRaH22
Jun 3, 2003 10:13 PM
