Tri Y to Apexi N1?
Old Oct 15, 2011 | 11:43 PM
Moo Shoo's Avatar
Default Tri Y to Apexi N1?
Hello, I am trying to fit a Tri Y header and my Apexi N1 exhaust together. There is a sleeve that comes out of the end of the header that wont go inside the exhaust. Can I just cut this part off and bolt them together? Is it bad to go from 3 inch to 2.5 inch?
Also the Apexi N1 has three pieces will I use all three on my BB6? One of them has three bolt holes instead of two...
Old Oct 16, 2011 | 09:09 AM
minilogoguy18's Avatar
Default Re: Tri Y to Apexi N1?
It's because the header isn't made to be used with a factory catalyst and the exhaust is. Easiest solution if you want to keep that exhaust is to have a pipe made to join the 2 so that in case you want to pull 1 or the other off to sell they wont be ruined from being welded together. You should also add a flex pipe in between the 2 as well.
Old Oct 16, 2011 | 12:09 PM
Moo Shoo's Avatar
Thank you. A couple hours later and quite a few more beers and I found this out. I was sitting on my bed for hours drinking beer and trying to make that header fit that exhaust :D
Now to find a exhaust shop that will make that pipe I need and not say anything about my missing cat...
BuiltCivic99
Jun 8, 2009 04:04 PM
DPGCLUDE
Aug 11, 2005 07:10 PM
sss2k921
Honda S2000
Jan 14, 2005 09:22 AM
hYpE-R-29
Sep 30, 2003 04:31 PM
hYpE-R-29
Jun 11, 2003 10:27 AM
