need help asap with brakes!
Old Oct 15, 2011 | 04:30 PM
dropped like its hott's Avatar
Default need help asap with brakes!
I replaced the rear pads and rotors on my brothers s10.. on one side i replaced a seized caliper as well.
i bleed the brake line on the side that i replaced the caliper, there is no more air comming through the line, but when i start up the truck the pedal is still sinking to the floor.
my question is that now that i have started the vehicle is the air in all the lines now? will i have to bleed all the lines? I would have just checked for myself but the problem is that the valves on all the old calipers are rusted to ****..
so i would like to know if that is what happened and im going to have to try and bleed them all or if that is not possible and something must be wrong with the side i replaced.
ps i know there is a brake forum but there is not much action going on there and i really need to get this done like now!
Old Oct 15, 2011 | 05:23 PM
fcm's Avatar
fcm
Old Fart
Default Re: need help asap with brakes!
Only way to know for sure is to bleed all the brakes in the correct order..
Pick up a can of MoveIt soak down the bleeder valves, hint, wrap the valve with cloth or stick a cotton ball on them and soak the cloth/cotton ball, let it sit overnight, use the proper wrench, [closed end] and see if the MoveIt worked, if still seized, try tightening it a tiny bit first to break it free, then try and open it. 94
Old Oct 15, 2011 | 05:26 PM
thanks fcm, so what your saying is that it is possible for air to have gotten in all the lines?
Old Oct 15, 2011 | 09:17 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Brake lines are divided into either split diagonal or split horizontal. Off the top of my head I believe the S10 is split horizontal. You have to bleed both sides, but not the front.
smoovekriminal
Apr 15, 2008 06:11 PM
SoneCorDC2
Aug 14, 2005 01:43 AM
Groove_D
Jul 3, 2004 01:28 PM
bOOsTiNSoHcVtEc
May 11, 2004 12:55 PM
