Fresh Tune up Problems
Bout two weeks ago i did a basic tune up on my em2. It was driving better for about three days and now its back to over rev'n
. So i checked the new plugs i just put in and they have carbon build up all on them they look just as bad as the ones b4 them any ideas of what i should do?
1) what did you replace with the tune up?
2) what do you mean by over revving?
3) is it an automatic transmission?
over revving is usually an auto trans slipping. nothing a tune up would fix.
oil
spark plugs,ignition coils
Automatic
when i say when it shifts on its on it doesn't sound smooth. It goes steady and then randomly jumps up like one or two RPM's then thats when it decides to shift
Automatic
I would recommend getting the fluid changed on the transmission. It would probably alleviate some of the slipping, if not all. Use factory transmission fluid, though.
You might want to do the 3 x 3 method.
Basically you do it drain it after say 300 miles or so, drain and then drive it again for 300 miles or so, total of 3 times. This gets all the old fluid or a lot of it out.
hamed
Apr 22, 2009 06:50 PM
black0hatch
Honda Civic (2006 - 2015)
Apr 7, 2008 08:13 PM
ferio252
Oct 28, 2007 04:40 PM
LSegHatchy
Sep 13, 2006 02:34 PM
