material on 3rd gen cat - b pipe flange?
Old Oct 14, 2011 | 06:22 PM
sebTeggy's Avatar
Default material on 3rd gen cat - b pipe flange?
95 ls
Hello TI,
I broke 2 bolts off of my cat, the part that connects to the B-pipe.
The part that connects to the header is clearly aluminum, but the triangular part that attaches to the b-pipe looks cast iron?
Here are two pictures
Is this part aluminum or cast iron? If it is aluminum, I will just get it welded to my B-pipe.... I don't really care since I take them both off at the same time anyways. If it is cast iron, then I somehow have to get the 3 old studs pressed out and replaced, which will definitely be more expensive than welding.
I have the cat and b-pipe off the car already. Tips appreciated, thanks for reading!
Old Oct 14, 2011 | 08:26 PM
fcm's Avatar
fcm
Old Fart
Default Re: material on 3rd gen cat - b pipe flange?
Heat up the "flange" drive the the studs out, use nuts and bolts, [or drive in a new set of studs] total cost should be $2-$5.
You will need a vice, a torch and a good sized ball peen hammer, [you may need a drift] a buddy to help is always good.94
Old Oct 14, 2011 | 09:47 PM
sebTeggy's Avatar
Thanks for the tips, Honda wants about 30$ for 3 new studs and bolts.... =(
All I have is a propane torch which I dont think gets nearly hot enough.
But, my main question, is this cast iron or aluminum? Because if its aluminum I will get it welded, where-as cast iron can't be welded.
Old Oct 15, 2011 | 07:44 AM
fcm's Avatar
fcm
Old Fart
It will be steel or cast, it is unlikely to be aluminum.
I would not buy from Honda, that would make it a car part, [$$$] get them at your local hardware store or nut and bolt shop, [fasteners].
A propane torch will be more then hot enough, all you need to do is heat it not melt it. 94
Old Oct 15, 2011 | 11:20 AM
sc34dc4's Avatar
It's not aluminum or it wouldn't be rusty. Just like fcm said go buy 3 bolts and nuts from a hardware store and you're set. M8x1.25 flange bolts and nuts would be my choice.
Old Oct 15, 2011 | 11:27 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
it's stainless steel, not t-304 which wouldn't rust, but a different grade, it's some extremely hard stuff, as I bored out a flange on my third gen accord, definitely not mild steel, all you have to do is heat up those studs and drive them out, if you can't find them in a hardware store, about any muffler shop should be able to get them, they deal with this all the time, it's an easy and cheap fix
Old Oct 17, 2011 | 05:55 PM
sebTeggy's Avatar
Yeah it was steel. Muffler shop had an acetylene torch and got all 3 out in about 60 seconds.... And gave me bolts and a gasket for 25$...
Honda wanted 50$ just for the bolts
Muchhh better!!
Old Oct 17, 2011 | 06:16 PM
fcm's Avatar
fcm
Old Fart
94
Old Oct 17, 2011 | 08:50 PM
sebTeggy's Avatar
Thanks again for your tip! You saved me big time, and got me an idea for my xmas list....
Acetylene torch!!!!
civicdelsol33
17
Nov 15, 2008 11:06 PM
Y2KEBPSI
Apr 22, 2004 01:09 PM
sohcvtec66
Feb 25, 2004 06:49 PM
jabenne
Apr 24, 2002 03:57 PM
