How do you properly store a welder/cylinder after use?
Old Oct 14, 2011 | 02:36 PM
TB123's Avatar
Default How do you properly store a welder/cylinder after use?
This probably sounds like a stupid question to those of you who have been welding for a while, but I just got a new welder and set it up with gas. The manual was good at explaining how to set the machine up, but says nothing about what to do after you are finished welding. Is it okay to leave the gas hooked up? Of course I closed the cylinder valve, but am I supposed to de-pressurize the lines or anything? The CFH gauge still has a reading.
Old Oct 14, 2011 | 02:39 PM
SpeedwayCoating's Avatar
Default Re: How do you properly store a welder/cylinder after use?
I always just cut the valve off.
titwack's Avatar
Yes you should always purge the lines after shutdown, clear the hoses and if you want, lay a towel over the machine to protect it from dust
Old Oct 14, 2011 | 02:47 PM
I am not saying its a bad idea to purge the lines, but whats the benefit? Now I have been welding for 10 yrs and never done it and have not seen any adverse effects.
Old Oct 14, 2011 | 02:58 PM
TB123's Avatar
How do you purge the lines? Just pull the trigger? That seems like it would waste wire. Is there another way?
Old Oct 14, 2011 | 04:29 PM
essex's Avatar
I never disconnect my lines , never even heard of that. Not saying its not true but I never heard of that. I could not use my machine for a month and never had a problem just leaving my lines hooked up.
All I do is close the tank valve and cover the machine.
Old Oct 14, 2011 | 04:48 PM
titwack's Avatar
i didnt mean disconnect the lines, i meant after you turn off the gas valve i push the pedal/trigger to purge out the gas, out of the lines. then shut off the machine
Old Oct 14, 2011 | 06:24 PM
essex's Avatar
Oh I see , my misunderstading
Old Oct 15, 2011 | 05:42 AM
joein's Avatar
Better machines have a momentary rocker switch labeled, "PURGE," that activates the gas solenoid but not the wire feeder. If you're worried about the tenth-of-a-cent's worth of wire that purging by pulling the trigger will waste, just release the drive roller clamp before you pull the trigger - voila, the rollers turn but no wire is fed.
Old Oct 15, 2011 | 06:02 PM
Seymour86's Avatar
With a MIG welder I will tap the trigger in very quick succesion. On the welder I have a millermatic 185 this will purge the lines while not wasting alot of wire.
rotascircuit
Mar 15, 2008 01:20 PM
Pandahatch
Mar 21, 2005 08:19 AM
civicshowracing65
29
Jul 20, 2004 05:26 AM
B18C_eg
May 11, 2004 06:27 AM
