92 Integra delay before turning over.
Old Oct 13, 2011 | 08:43 PM
daricky's Avatar
Icon3 92 Integra delay before turning over.
As I turn they key to turn over the engine there is a delay before the engine actually turns over. Sometimes it will be a 1 second delay or longer. Or sometimes it wont start at all. But as soon when it does crank over it turns on like nothing is wrong. I have recently replaced the main relay and the distributor. Do any of you have any ideas of what it could be. Or any recommendations of what to replace or check.
Old Oct 14, 2011 | 02:56 AM
hondahead_dave's Avatar
Default Re: 92 Integra delay before turning over.
that is a good question, mine does the same thing, what I do is turn the key, wait until the dash lights turn off, then fire her up, starts every time. My car has done it as long as I can remember.
Old Oct 14, 2011 | 09:33 AM
DA Darkside's Avatar
Same here, i think its just the safety switch that allows your car to start when you push the clutch down. Cause mine only starts when i turn the key all the way trying to start it, then i push the clutch pedal down and let it off pretty hard, and doing that a few times usually does it for me. This just started to happen in mine maybe this month
Old Oct 15, 2011 | 11:53 AM
ninjaturtleEG's Avatar
Its probably your ignition switch. I had the same problem, it got longer and longer to start and eventually it wouldnt even start and left me stranded. Replaced that and haven't had a problem and its been a year now. Easy to replace, unless you have an alarm wired into it.
Old Oct 16, 2011 | 11:41 AM
daricky's Avatar
Thanks I will look into the ignition next and let you know what happens. Thanks for the input.
Old Dec 27, 2011 | 09:59 AM
italian_virus's Avatar
im having the same issue.. but i did a b18c1 swap in my civic..
the issue im having is on certain days ill notice that when i try and start the car it either has a delay of about 1 to 3 seconds to about sometimes 10 seconds.. even to the point where ide have to wait cause it would not turn over..
i upgraded my fuel pump to a walbro 255 i believe.. and my igintion system is an MSD with an external coil..
i notice i do get bogging at low even high RPMS.. and sometimes i have erratic idel issues, where the RPMS drop VERY LOW to where it almost stalls and then i notice the ECU picks it self up and goes back to 1000RPMS.
from what ive been reading it could be either the ignition switch or the ECU itself..
any thoughts guys ???
thx
Old Dec 27, 2011 | 10:00 AM
& i should have asked this prior..
but can a bad ignition switch cause bogging in a motor?
Old Dec 27, 2011 | 10:02 AM
& i get no check engine lights or anything like that
Old Dec 27, 2011 | 11:04 AM
b20bFourDoorCivicLX's Avatar
i have a problem with my 90 integra ls , every morning or in other words cold start, because at work after not starting my car for atleast 3 hours it has a delay like it wont start it cranks fine, lights turn on fine, everything that has to do with it starting it fine or i would think....im assuming it would be my fuel pump
Old Dec 27, 2011 | 12:54 PM
HondaPartsHero's Avatar
Technical Hero
Also could be your starter on the way out. Same symptoms in my 90 Integra, one day it just wouldn't start.
Old Dec 27, 2011 | 03:36 PM
Gsrsi's Avatar
Could it be bad grounds?
Old Dec 27, 2011 | 03:56 PM
b20vteclsintegra's Avatar
Yeah check the grounds mine did that all the time and today I noticed that my ground on the starter was really lose so I tighten it but my dumb self didnt disconnect the battery and blow a fuse some where so know I have to track it down
Old Feb 3, 2012 | 09:33 AM
do you guys think it could be an ignition switch??
i was reading alot of forums and some guys said it was their ignition switch on the way out
Old Feb 9, 2012 | 07:00 PM
AlexDB1990's Avatar
You can always jump the starter from the battery and see if it has a delay. That's how I would always test my starter if it was going bad.
dc4b20
Jun 20, 2009 06:09 PM
The Captain
Feb 26, 2007 08:08 PM
03K24A4EX
May 26, 2006 04:47 AM
Chief Brody
Aug 30, 2005 08:58 AM
indy
Jul 1, 2001 09:40 AM
