gsr civic coupe
1998 Honda civic coupe ex
$3000
was kicked in passenger door and passenger quarter panel
No rust.
b18c1 gsr swap with 70-80K-professionally done
S80 transmission
integra rear disc conversion
CAI
New Oem civic si motor mounts
Obx header
New stage 2 clutch
Type r cams
Has a/c which works
No power steering
has S2 lowering springs and coil over buckets but at stock height
New oem flywheel
New windshield
Inspected
Aligned
Si rims with good tires(2 new)
New headlights
new water pump
new timing belt
new oil pump
new starter
new front axles
new rear rotors
new rear pads
new rear bushings
new front rotors
new front wheel bearings
aftermarket ignition switch can be tricky if you aren't familiar with starting
bad-
Had some hail damage. Replaced hood and trunk
Couple dings in front fender
Passenger door looks like it was replaced
Rear quarter was sprayed.
http://i243.photobucket.com/albums/f...813_142712.jpg
http://i243.photobucket.com/albums/f...804_141058.jpg
http://i243.photobucket.com/albums/f...525_161955.jpg
can get more pics
$3000
No rust.
S80 transmission
CAI
Obx header
New stage 2 clutch
Type r cams
Has a/c which works
No power steering
New oem flywheel
New windshield
Inspected
Aligned
New headlights
new water pump
new timing belt
new oil pump
new starter
new front axles
new rear rotors
new rear pads
new rear bushings
new front rotors
bad-
can get more pics
not really. I tried taking it but is very hard to make out in the pictures. it is primarily on the roof with a couple (10 or so) on the frt and rear fenders. on the roof there is probably 50-75 dings from hail the size of nickles, so the dents aren't quite that big.
thanks
thanks
