what alternator are you using (d series) guys
Old Oct 13, 2011 | 06:44 PM
KINGVEM^^ED6's Avatar
Default what alternator are you using (d series) guys
Sooo I'm pretty sure my alternators slowly going out
I'm running a y7 with a obd0 alternator with a swapped out pulley to four rib
Soo I'm gonna get a new one but idk if kragen/vato zone has a four rib pulley obd0 alt.
So I wana know what you guys are doing??
I don't have access to a compressor/impact here so idk how easy its gonna be to swap pulleys :/
Old Oct 13, 2011 | 08:20 PM
Clipsed's Avatar
Default Re: what alternator are you using (d series) guys
go to a shop like last time you pu$$Y!
Old Oct 13, 2011 | 09:35 PM
tonylovesjdmEF9's Avatar
Ship one? I think it would fit in a flat rate box
Old Oct 14, 2011 | 04:04 AM
TearSDMF89dx's Avatar
im running a napa 70 amp from a 95 ex it came with a four rib pulley ...i used to have the obd0 one that came on the car but i decided to upgrade....its all plug and play
Old Oct 14, 2011 | 04:31 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
^^^ That is what I have done in the past.
Old Oct 14, 2011 | 04:49 AM
ewok1's Avatar
i did the same with no problem ^^^
Old Oct 14, 2011 | 04:59 AM
So eg alternators are plug and play on ef?
Old Oct 14, 2011 | 05:42 AM
ewok1's Avatar
i ran a sohc zc ,mine was off a 95 civic and was plug & play .it should work bro,these engine components are nearly the same and interchangable
Old Oct 14, 2011 | 05:46 AM
Projekt_ED3's Avatar
The plugs on the alternators didnt change until obd2 i believe. I know this is slightly different but im running an obd1 integra alternator on my b18 in my obd0 ED3 all the plugs are the same just had to bolt it up and plug it in.
Old Oct 14, 2011 | 07:12 AM
DO IT ON ALL FOURS
OBD-0 and OBD-1 alternators are the same electrical hook-up wise - utilizing the round plug. OBD-2 is when they switched to the square plug.
Old Oct 14, 2011 | 08:23 AM
boosted.CRX's Avatar
I'm running an OBD2 ZC (JDM Y7) in my OBD0 CRX, using 4 rib pulley and an OBD1 D-Series alternator (for more amps). Kind of a **** mix but it works well besides being somewhat difficult to get on.
Old Oct 14, 2011 | 10:19 AM
julioboostamante's Avatar
any reason to run the 4 rib pulley?
Old Oct 14, 2011 | 11:11 AM
more rubber on the pulley = less stress on the belt
Old Oct 14, 2011 | 11:36 AM
DO IT ON ALL FOURS
The 4 rib is what an "injuneer" came up with to allow the belt to have less stress/not slip for the higher amp alternators. Not only this but the later crankshaft pulleys are obviously 4 ribbed. The 3 rib has a minimal amount of less drag added with the lower amp alternator - but the benefit is negated by the higher amperage. Obviously, if you had a full out race car and HAD to still run the alternator you could run the smaller belt/alternator to squeeze out that last ~0.1 hp... haha.
It all depends on what the serpintine belt is running - on some vehicles they are up to 8 ribs or so... and I believe even more...
Chemi421
10
Aug 25, 2010 09:04 PM
alexm
May 10, 2009 09:24 PM
BAZ
Nov 7, 2008 04:25 PM
mister.wong
Jan 24, 2008 12:04 PM
APEX CRX
Jan 28, 2004 10:30 AM
